996 Forum 1999-2005
Cab plastic rear window separation
Old 11-28-2016, 12:07 PM
wyovino
wyovino's Avatar
Having tried the repair route and then biting the bullet for a new top, my recommendation is to get a new top. You can have one installed in the $1600-$2200 range depending on your location and whether you go with a plastic or glass window. A dealer will charge you over $6000.
Old 11-28-2016, 02:20 PM
frisbee91
frisbee91's Avatar
Originally Posted by darcimaui
So do I sew around the window from the inside and out? I just came home from a vacation to a fallen out back window.
Click the link in post #13 above. There is a detailed write-up there. I did the repair 6+ years ago, and it is still holding up.
Old 12-05-2016, 03:26 PM
albaran
albaran's Avatar
If you replace the top, it is well worth it to buy the glass version.
Old 12-05-2016, 06:01 PM
wyovino
wyovino's Avatar
That's a matter of personal taste. The replacement top glass window is very small. Take a look at both and decide for yourself.
Quick Reply: Cab plastic rear window separation
