Rain issues
So my 996 C2 has decided to freak out in the rain storm we're having here in L.A.:
CHECK ENGINE light comes on.
ABS light comes on.
PSM light comes on.
Engine sputters and dies on acceleration.
Engine surges wildly on idle.
I can't believe this isn't somehow related to the rain (it happened twice during heavy downpour on Monday and Wednesday, but was fine on drier Tuesday).
Anybody ever had a similar issue? Should I just wait for the car to dry out and try again? Or just bite the bullet and have it towed in for repair? Any advice appreciated. Thanks.
ABS light comes on.
PSM light comes on.
All I can think of is check and see if you have water getting past the seals under the hood in front and in the engine compartment. With that amont of errors I'd think it's a connector. Have you added anything electrical lately? Verify connections on sockets and look for water near the fuse box. Do not clean any white stuff off of plugs and sockets, its to keep water out and preserves metal contacts. Actually not sure where the ECU is but I think its in front so make sure it isn't getting flooded.
Um, might look at the coil............nevermind
Yeah this rain has been crazy all week, mine is tucked away in the garage.
Coil packs are often slightly cracked, which is not a problem until water gets up in there.
Do you have it parked somewhere?
It's supposed to dry out tomorrow (Sat), maybe the problem will solve itself, wouldn't that be nice.
Good luck.
Good luck.
Thanks for the advice.
I left it parked (at my office) all day today. Will try it again tomorrow, which is supposed to be relatively dry also.
I'll have the coil packs looked at. Just hope I can drive to the shop and not have to have it towed.
