brake pads
NEW Pagid "S" or "Sport" - This is a high performance compound with good fading characteristics and high cold friction. The most comfortable medium friction sport compound. The Sport Pad is street legal, rotor friendly and OE on various Ferraris and Corvettes. PAGID "S" Brake Pads are dipped in a anti-corrosion blue paint, with a layer also on the friction surface. This paint coating will disintegrate during the first braking applications without any loss of friction compared to our other non-coated compounds. In addition a majority of the "S" Line come with anti-noise shims. The "S" compound is the PAGID RS 4-2-1.
I'd be lying if I said the Pagid Yellow Endurance (RS19) don't squeal. It's ridiculous. Although they're more aggressive than normal pads, but less than the outright track Pagid Blacks.
I prefer these to the RS44 Orange ones.
IMO, the braking system and the tires should be upgraded together. Running an agressive pad with street tires is not a good idea - and likewise, running stock pads with R-comps is not a good idea.
If you have other problems with the brakes, maybe we can assist, but as presented, I can't see any real reason for you to upgrade pads.
-td
The reason is that on this weekend DE track driving, while in the inspection prior to racing, I was told that I will need to replace my brake pads and resurface the discs if I want to run on the next DE. While at the track, the car was braking perfect without any problem, I also was told that the brakes look OK for street driving.
Apparently they have certain brake pad wear restrictions for racing.
And, although you'll be driving fast, it will be far from racing.
-td
In my experience you can burn through a new set of stock pads in 2-4 days of DE driving depending on the track even with street tires. A more aggressive pad can greatly extend that life.
Good luck with your search.
Why is a more aggressive pad on street tires, "not a good idea"? I don't see anywhere in the OP post where he suggest he is looking at a full on race pad and I don't see any real problems going to a harder pad with street tires (although I would recommend a brake fluid upgrade with a pad upgrade).
2) Track pads are substantially more expensive than street pads, so the OP is wasting money at this point. The OP doesn't need to brake faster, better, harder, modulate better, etc. He needs to learn how to brake, threshhold brake, trail brake, etc., which can be done cheaply with stock parts.
3) When driving on the street, agressive pads are like sandpaper on the rotor, resulting in reduced rotor life. When you are on the track, you have a transfer layer of pad that reduces rotor wear. So you should use track pads on the track - not so much on the street.
4) I think you actually meant softer pad, as a harder one would make braking worse. (Aggressive = softer) Pagid blacks are not harder than pagid yellow.
5) I'm sure there are other reasons, but those are the first ones that popped into my head.
Sure, all the track junkies have burned pads in 1 weekend, corded tires, heat cracked rotors, etc. But I haven't ever seen a green student eat a set of pads in their 1st or 2nd time out.
Lastly, there is more to braking than just changing pads. The car is a system, and needs similar parts to perform optimally. At a minimum, when you upgrade brake pads, you need to upgrade tires as well, and (typically) vice versa.
-td
Second Zookie's recommendation for Porsche sport pads. My wife runs them in the black group with R-compounds and I drive them on the street every day. Not an all out track pad but does both well, especially if you're just starting.
I think it is bad advice to advocate upgrading parts to a complete novice. On the track, agressive pads will lock up the tires with less pressure. This makes learning harder and driving harder. The typical novice needs the car to operate correctly and balanced, and has no skill set to fall back on. For an experienced driver, this may not be a concern, but for a 2nd time DEer, I think ANY upgrades to make the car perform better are not a good idea. They won't know anyway -as they have no baseline to compare it to.
Try to remember your 2nd DE. You didn't need upgraded parts to go faster. You needed coaching and seat time. IMO, it is a disservice to tell newbies to go out and upgrade brake pads, rotors, tires, suspension, etc etc without understanding WHY they need new parts. The OP stated his car needed new parts to participate, not that he couldn't stop, not that he was eating pads too fast, not that he was overheating. To me, this means he should still be running stock equipment.
-td
-td
Second, as he stated he's not looking for a full on track pad, he just wants something that will last longer and not squeal. Such a pad would have minimal impact on rotor life or lockup characteristics. There are plenty of mild pads out there that represent just such an improvement over stock and it seems pretty clear that's what he is looking for.
As I stated, I think it's far more important for him to upgrade the brake fluid with a pad upgrade. This is more important than worrying about running on street tires at this point (and at DE #2 it is too soon to worry about upgrading the rubber).
Sorry, I see a mild pad upgrade as no big deal so I'll agree to disagree.
