996 Forum 1999-2005
Spark plug tube replacement
Old Nov 8, 2009 | 09:07 PM
goliver's Avatar
goliver
Pictures of tap and how I used it to pull the tube and the inside of a tube after removal. Sorry that picture quality isn't the greatest. Not much of a photographer. You can see that the tube doesn't get to stressed from cutting some light threads inside. They could be reused. I had already purchased new tubes and o-rings so I installed the new tubes. Tubes not cracked just bad o-rings.
File Type: jpg
File Type: jpg
Old Nov 8, 2009 | 10:10 PM
function12's Avatar
function12
I have also heard people use a boat plug to pull the tubes.
Old Nov 8, 2009 | 10:20 PM
goliver's Avatar
goliver
Boat plug is a good idea. I own a machine shop so just grabbed what was lying around. Heard some just pry out with screwdriver. Didn't want to risk breaking anything that might be hard to retrieve.
Old Nov 9, 2009 | 02:30 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
thanks for the tips!
Old Sep 16, 2010 | 12:42 PM
papachili's Avatar
papachili
I have a 2004 996 C2 and the right side cam cover area is oily with a few drops a week noticeable on my garage floor. I would like to replace the spark plug tubes/O rings first as many have suggested. However, on a related post, someone mentioned a MK2 996 must have the cam cover removed to replace the tubes/o rings...is this correct?
Old Dec 13, 2011 | 12:59 AM
mikeswift's Avatar
mikeswift
Originally Posted by 1999Porsche911
There have been a few bad tubes, but the most common cause is the O rings.
do you have the part number for O-rings 99 996 convertible?
Old Dec 13, 2011 | 02:33 AM
pmkazz's Avatar
pmkazz
Default Spark Plug Tubes
Replace mine last month. Here is what I found...
File Type: jpg
File Type: jpg
Old Dec 13, 2011 | 10:07 AM
Torontoworker's Avatar
Torontoworker
Originally Posted by Mary58712
Does the issuance of a TSB suggest the repair will be handled by the dealer at no charge?
Only under warranty. TSB's identify a non safety issue for dealers and tech's and describe the procedure to correct it.
One major difference between a recall and a TSB in the automotive industry is that a recall usually evolves out of safety issues at the behest of an organization like the National Highway Traffic Safety Administration (NHTSA). The ensuing recall maintenance/repair work is usually done at no charge to the car owner, regardless of the car's warranty status. Dealers are usually under no mandate to call in cars for which there are TSBs to do the related repairs. Nor is there an obligation to do the TSB repairs for free or at reduced charges to the owner.
http://en.wikipedia.org/wiki/Technical_Service_Bulletin
Old Dec 13, 2011 | 12:01 PM
fpb111's Avatar
fpb111
That post is from 2009, try here:
http://www.pelicanparts.com/cgi-bin/...FILTER_996J=ON
Old Dec 13, 2011 | 12:05 PM
tbanasiak's Avatar
tbanasiak
Most likely the leak is from bad O rings. New ones can be purchased from the dealer or you can pick up O rings of the same size at a hardware store.. There is a TSB issued for the O ring problem. Plugs must be removed for access of tubes.
Can be done with plugs in place. I would recommend getting a 1" boat transom plug, makes removal and install a snap.
