996 Forum 1999-2005
Spark plug tube replacement
Old Mar 31, 2009 | 11:57 AM
Ubermensch's Avatar
Ubermensch
Default Spark plug tube replacement
I swapped out my plugs this weekend and notice three of the six tubes had minor leaks. I need to order some replacements, but I have two questions:
a) Can I replace the tubes without removing the spark plugs (just being lazy since I just replaced them)
b) I didn't remove the exhaust to do the plug change. Will I need to remove it for the tubes or is there enough clearance?
Thanks,
Shawn
Old Mar 31, 2009 | 12:01 PM
1999Porsche911's Avatar
1999Porsche911
Most likely the leak is from bad O rings. New ones can be purchased from the dealer or you can pick up O rings of the same size at a hardware store.. There is a TSB issued for the O ring problem. Plugs must be removed for access of tubes.
Old Mar 31, 2009 | 12:27 PM
Ubermensch's Avatar
Ubermensch
Does the issuance of a TSB suggest the repair will be handled by the dealer at no charge?
Thanks for the heads up on the removal of plugs.
Old Mar 31, 2009 | 01:03 PM
gota911's Avatar
gota911
Newbies Hospitality Director
No.
Old Mar 31, 2009 | 04:52 PM
rb101's Avatar
rb101
When I replaced plugs at 90K, I found 3 tubes that had oil in them and all 3 had cracks in the tube causing the leaks.
Old Mar 31, 2009 | 06:21 PM
1999Porsche911
There have been a few bad tubes, but the most common cause is the O rings.
Old Mar 31, 2009 | 11:06 PM
salayc's Avatar
salayc
You can pull the tubes without removing the spark plugs.
Old Mar 31, 2009 | 11:22 PM
porsche52's Avatar
porsche52
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
You can pull the spark plug tubes with or without the plugs installed, that is the least of your worrys though, as pulling the spark plug tubes is alot easier said then done most of the time. I use a device that goes into the tube and expands, then you twist and pull the tube out, by using this method the tubes break/crack about 50% of the time, IMO they should be replaced everytime regardless, its plastic!!. Another method is to use a screw driver or pry bar to try and lever them out, but the tight clearances in this area make this method a pain in the butt for most. Some will come right out and some will fight you. Be very carfull not to break the tubes to the extent that plastic debri falls into the cam housing, this could be very bad!! When the tubes are out, clean the surface on the cam cover very good, lube the new o-rings fitted on new tubes with oil our something of that nature to allow for proper installation. When installed properly they will sit flush into the cam cover. Good Luck
Old Apr 1, 2009 | 07:53 AM
1999Porsche911
Yes you can, but it is a lot easier to have the plugs out so you can grab the inside of the tube farther down to pull out so you don't break them. It also allows you to clean the oil off the plugs.
Old Apr 1, 2009 | 10:43 AM
Ubermensch's Avatar
Ubermensch
Thanks for all the tips. So far the leaks are just at the surface and I don't see any oil on the plugs I just removed.
Old Nov 7, 2009 | 04:54 PM
hantsbad's Avatar
hantsbad
I replaced my tubes today. I took out the spark plugs and one did break and I cant account for 1/8 around piece of the plastic tube. I look for it but could not find it. What should I do. Should I be worried?
Old Nov 7, 2009 | 10:12 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Photos?
Old Nov 8, 2009 | 02:32 AM
goliver's Avatar
goliver
I was worried about breaking part of a tube and not being able to fish it out so I used a 1 1/16 tap if I remember correctly to grab the tubes from the inside. I'll check to make sure I have the size right if anyone is interested. In any event, exhaust on, spark plugs in, screwed tap in until whole tube spun. Grabbed end of tap with a pair of vise grips and using a long screw driver as a lever popped them right out super easy. Have photos too if anyone is interested. O rings bad on three tubes. Anything over 3500 rpm and it looked like I was fogging for mosquitos. Would be willing to share and or mail the tap with anyone who wants to use it to do likewise.
Old Nov 8, 2009 | 05:33 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
I would like to see some photos.
Old Nov 8, 2009 | 07:33 PM
goliver's Avatar
goliver
I'll load em up from my camera when I get to work in the morning.
