Time for and updated baby seat model thread? Past threads have outdated names, etc.
#406
I also found this today which looks like it might fit well but its a little pricey.
Has anyone tried this, and if so any thoughts are much appreciated.
Here is the link
Amazon.com: Clek Foonf 2013 Convertible Child Seat, Drift: Baby
Here is the link
FYI, the experiment I performed with the retrobelts seat belt (see earlier post) was unsuccessful because the fixed belt length was too long resulting in buckle crunch when I tightened the best. I'm hoping I will be able to use the Brey Krause mounting points (earlier post) with the latch belts that came with my Diono Radian as a final solution.
I'll also spend sme more time following 'thewheelman' suggestions to use the stock seat belt today.
I'm getting closer :-)
#407
I have a 2013 991 cab. I've been able to get the Britax Marathon to fit with no modifications and it seems very solid. This does however compromise the room left for the front passenger seat. I utilized the rear seat shoulder\lap belt as well as the LATCH system to secure the seat. $300 at Baby's R' Us, but I think you can find them cheaper online.
#408
I can confirm that the Maxi-Cosi Rubi works well for a toddler seat. The belt system is ingenious and really makes the whole setup viable. The big problem I found is that the lap belt anchors sit too far forward of the belt routing channel on most seats. The Rubi is the only seat I could find that routs the lap belt around the front of the seat base. And the shoulder belt routing is equally secure. I'm going to try removing the seat back to get a couple more inches for the front seat passenger, but even at this point it's a ton better than the infant seat.
Only problem is that it's a PITA to get. Took me about 6-7 weeks for delivery from Switzerland. But it works really well and is obviously a well-made seat. Much better quality than most of the other seats I've seen.
#409
I am using a Diono Radian RXT - thread with details here:
https://rennlist.com/forums/996-foru...-year-old.html
#410
From this thread it appears that the only seats that are fitting well in a 996 without modification is the Porsche Junior and Maxi Cosi Rubi? I appreciate confirmation as there are a number of us with a child that has outgrown the infant seat (I used the cybex) and need to replace in order to drive the summer Porsche. Also, anyone have a newer Junior for sale? Thanks -
Jeremy
Jeremy
#411
Jeremy
Jeremy
I bought a second one a month ago so the two rear seats have matching Porsche Junior seats!
#412
I have read in other threads that the Porsche seat is a white label version of the Britax Marathon. Given the various ages of these threads - is there a way to determine which model marathon is the same as the Porsche junior?
#413
#414
#416
#417
And yes, I'm also looking for something for a kid who has just about outgrown the Cybex Anton.
I'd prefer something that can go in the rear seat AND be rearward facing until he's two. Can the Maxi Cosi Rubi or Porsche Junior do that? (In fact, can the Rubi be rearward facing in any seat? Someone posted above that it can be used in both directions, but according to the Maxi Cosi website, it's a forward facing seat.)
Alternately, instead of a rearward facing seat, a seat that uses a padded cushion instead of a harness would probably be OK - anyone know of any such seat that works in the rear of a 996?
Finally, it seems that most of the top rated seats nowadays only install with Isofix/Latch. (I'm assuming that Isofix and Latch are exactly the same but for the name.) There were one or two posts in this thread about setting up a 996 to work with Isofix/Latch seats, but with no details or conclusions. And also a link to a thread saying the Brey Krause harness mounts work with some Isofix/Latch seats, not others - which does not sound like an ideal solution. Has anyone found a better way?
#418
In case it's helpful, the following seems to get good test results and were either noted as using little space, or at least were not noted as being very big. To my knowledge, all are front facing except the first (hence "2 way"):
Maxi Cosi 2 Way Pearl (Isofix only)
Concord Ultimax 2 (Isofix only)
Kiddy PhoenixFix Pro 2 (pad instead of harness, very safe, very ugly)
Maxi Cosi Priori fix
Chicco Oasis 1 (isofix only)
Romer/Britax Trifix (isofix only)
And the Cybex Sirona looks cool, but I haven't seen test results, I've no idea how big it is, and it's isofix only.
#420
Here is my contribution. I have not tried any of these yet, but Maxi Cosi has a handy tool on their website that purports to help you select car seats to fit 911s from various model years, depending on the size and age of your kiddo.
http://maxicosi.carseatfitting.com/f...en/porsche/911
