Bummer
#91
Doug, this is an awesome thread, sorry it is really at your expense, but I know I for one am learning quite a bit. Please keep your "hobbyist mechanic" pics and descriptions coming and keep us up to date.
#92
Sad result, but awesome photos and posts! You know your **** Doug! If that happens to me, I pray it will be before my extended warranty runs out next month!
#93
Also, those plastic variocam chain guides look very much like the plastic guide on the cam chain tensioner on the 944 S2! Mine looked about as worn when I replaced it on the S2.
When the guides go on the 996, does that result in catastrophic failure, like in the 944??
#95
#96
I was happy to help...
This level of internal plundering is beyond the scope of many... We want to change that.
That said, I am assembling a stroker M96 engine tonight... What a bitch!
(but I love it)
(but I love it)
#98
I am also a hobbyist mechanic and installed my own fabspeed cold air intake, sport exhausts and spacers.......YOU ARE A VERY ADVANCED HOBBYIST MECHANIC.....one that I would like to have as a neighbor....... keep us updated.... this is the best rennlist post EVER! Still sorry you have to do all this and can't just drive and enjoy!!
#99
What a brilliant thread. I'm sorry for your misfortune but, you've turned it into an incredible source of information for our community. By the way, you're quite a few levels above hobby mechanic as in my day when I was working on my Jeep, I considered bolt-ons and lift kits as hobby level. Extracting the motor, tear down and creation of tools is quite a bit more.
With my 996, my level of tinkering is changing my steering wheel, seats, exhaust swap, oil changes and the like. I'm going to attempt cleaning my radiators tomorrow.
Thanks again for the great info and I hope you get her back on the road soon,
#100
I had some time to do some more parts disassembly and cleaning over the weekend, and thought I'd put up some pics showing something ugly that I found inside the oil pump. Apparently, at some point in the engine's 67K miles of use, some trash made it's way through the gears and damaged the pump housing and the gears.
I suspect the trash was a piece of the seal tensioning spring I found in the sump and posted a picture of earlier in this thread. So now I need to add a new pump housing, cover, and gears to the list of parts I'll need if/when I reassemble the engine:
#101
on the cam soilenoid assy, do you see any way or reason that oil would seep THRU the solenoid? (coming out of the wire seal) I know on one of the cam guides there is an O ring under it and not on the other... but what path would oil take... just curious...and do you plan to take apart that assy to replace any o rings or seals inside of it?
#102
Parts Specialist
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
AWESOME !! Thank You !!
It looks like the solenoid has a drain or galley in the housing and is "open" to oil on the mounting surface. That is differant from what I was thinking. So any oil on that surface is not under pressure, but just there... is there anything or anyway for oil to go thru the solenoid? (cant see the mounting surface side) weird that mine seems to have oil coming out the wire.....(or did at last check)
awesome pics.. again thanks
#103
Here's a better pic:
#104
Parts Specialist
You are awesome... Thanks a million for the very detailed photos and insight.
What do you think about your motor... are you planning to get it running or is this a one way trip (tear down) -
#105
It also seems that 3.4 heads are a little scarce (at a reasonable price anyway, given their tendency to destroy engines) so that may ultimately come into play here as well. I did talk to a guy in Costa Mesa who claims to have welded these heads up before, but I haven't yet done any research to verify his claims.
