996 Forum 1999-2005
Brakes and rotors
Old 11-20-2007, 05:15 PM
RUSSCPA
RUSSCPA's Avatar
Default Brakes and rotors
What has been your experience with brakes and rotors?
How many miles have they lasted and how much have you paid at the dealer and local P-Car mechanic.
Thanks much and a happy and a healthy Thanksgiving to all.
Gary
2004 C2 CAB
Old 11-20-2007, 05:34 PM
pat056
pat056's Avatar
Read the DYI on replacing pads. It's very easy IMHO, and I'm no grease monkey! No experience on the rotors yet and I have 72k miles.
Old 11-20-2007, 08:45 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Russ, you can skip the thread titled Changing Brake Pads-How not to do it.
Actually there is a link in the above thread to a brake pad DIY on RennTech.org that would be helpful.
Old 11-20-2007, 09:46 PM
RUSSCPA
RUSSCPA's Avatar
For thoses that have paid, how much has it cost and what has been your mileage experience?
Old 11-20-2007, 10:18 PM
himself
himself's Avatar
My worst experience: I had a lip on my front rotors after about 15,000 miles, so I put on new pads (all the way around) and rotors (up front only). Went to 3 DEs, and on the way home from the last one, one front rotor was chewed up a little from vanishing brake pads, i.e., need new front rotors AGAIN. So, in the span of one month I had to get 2 sets of rotors and 2 sets of pads all the way around - and new fluid (twice). 2 front rotors and 4 sets of pads are about $1000 (including parts and labor) at my shop. DOH!
-td
Old 11-20-2007, 10:32 PM
DreamCarrera
DreamCarrera's Avatar
-td
A "lip" on the brake rotor is pefectly fine and is normal. What is important is the thickness of the actual rotor. I believe that new 996 rotors(fronts) are 28mm thick when new and can be used until a minimum thickness of 26.5mm, measued in the middle of the rotor surface, not at the lip.
Also, pads are good until a minimum thickness of about 2mm - 3mm. However, if you track the car DO NOT let them get that thin.
Old 11-21-2007, 12:36 AM
himself
himself's Avatar
Although the lip is normal, it is also a rough indicator of how much wear your rotor has. If you wear down more than about 2mm on a side, you should probably take them in to be looked at. Some lip is ok, too much lip and you should replace them. Saying you "lipped" your rotor implies you wore them down beyond factory specs. I would guess that 40-50 hours of on-track time should do it
-td
Old 11-21-2007, 12:33 PM
RUSSCPA
RUSSCPA's Avatar
Thanks for your detail.
So, what has been your experience for your first brake/rotor job- miles and cost?
Old 11-21-2007, 12:42 PM
every day
every day's Avatar
Russ, I replaced mine at 25000 after a combination of street and track use. I did it myself because it is a very simple job.
I plan to continue watching your thread to see how many posts it takes to get your original question answered... haha!
Old 11-24-2007, 07:34 PM
RUSSCPA
RUSSCPA's Avatar
Anyone have an answer.
Old 11-24-2007, 08:56 PM
gota911
gota911's Avatar
Gary
2004 C2 CAB
Gary
1) my rotors and pads are original and I have 44,900 miles on them.
2) see answer #1
Old 11-24-2007, 09:17 PM
axelray
4th Gear
axelray's Avatar
The 1999 C2 daily driver I just purchased had 63K miles on it and (I suspect) original rotors. They were worn maybe .15 inches and the brakes did not feel super solid. I took a look at the calipers and they were great. Amazing piece of gear.
I had rotors and pads replaced all the way around at a non-dealer shop. Parts were $700-800 and it took about 3 hours labor. Don't have total cost because it was part of my purchase transaction.
Rotors are about $500 and pads can vary between $300-700 for all four wheels.
Even more if you want to splurge. Again, my numbers are for daily driving, not racing.
I'd like to hear what labor rates people are paying around the world.
Old 11-24-2007, 09:48 PM
RUSSCPA
RUSSCPA's Avatar
Thanks guys appreciate it. Anyone have a cost from the dealer?
Old 11-24-2007, 10:44 PM
Tonger
Tonger's Avatar
Russ,
I've had the front pads changed at 30k miles as a "precaution" from an independent tech before a DE. I think they were only 50-75% worn but he thought that running on thinner pads at the track could cause heat damage to the calipers. I don't how much truth there is to this but I think he charged me about $240 to do what is essentially a 15 minute job including pads. The next time around I'll just get them myself. I was pressed for time as this was literally two days before the DE and I didn't want to take a chance on failing my tech inspection.
OEM brake parts are actually fairly priced when purchased online...
Front OEM rotors: $243
http://e-partssales.com/Merchant2/me...6BrakesCarrera
Front OEM pads: $121
Rear OEM rotors: $205 (less frequently changed than fronts)
Rear OEM pads: $88 (ditto...)
I purchased a brake bleeder as well and do my own flushes. Just don't get it on the paint!
http://www.trackhaus.com/0109-black-...cts-p-276.html
My suggestion would be to go to Renntech.org and purchase a membership (one time fee). The dough you save by doing this yourself will pay for it many times over.
Good luck,
Tonger
Old 11-24-2007, 11:43 PM
aben8057
aben8057's Avatar
Russ,
The pads are simple to replace. Have a shop cut the rotors and save yorself $$$. This is a DIY job.
Quick Reply: Brakes and rotors
