996 Forum 1999-2005
A thing of beauty... AASCO Lightweight Flywheel
Old 10-31-2007, 06:14 PM
nosub
nosub's Avatar
Default A thing of beauty... AASCO Lightweight Flywheel
WOOT! UPS came and left not 5 minutes ago...
Great deal at $800 shipped ($750+$50 for 3 day UPS) from Ultrarev.com. Ordered Monday afternoon, in my hands on Wednesday.
Pcar is up on stands waiting on the clutch kit to arrive from Suncoast. Install on Friday and off we go!
This is why I prefer to do any of the maintenance myself that I can. Figure around $600 or so labor for clutch replaced at the dealer which is not much less than the flywheel. Win-win..
Yes, I have heard about the chatter, etc. have driven cars with LWFW's before (last was a '90 300ZX Twin Turbo with a twin plate clutch and Unorthodox LWFW. It was dyno'd at just shy of 425 RWHP and while there was some chatter it was not unbearable by any means). Basically it is a trade off.
Old 10-31-2007, 06:53 PM
Doug Donsbach
Doug Donsbach's Avatar
I think I'll do likewise when the time comes.
Old 10-31-2007, 07:13 PM
Steven C.
Steven C.'s Avatar
As long as the ECU can keep up with it? Have one on my 964 and love it but the car does stall every once in a while. Will also take stress off of the rear main seal, so might help avoid a leak??
Old 10-31-2007, 07:50 PM
redridge
redridge's Avatar
Not sure about that... it does chatter, more vibration.
Old 10-31-2007, 08:37 PM
UCrazyKid
UCrazyKid's Avatar
Can these single mass flywheels be resurfaced?
Old 10-31-2007, 08:38 PM
karlooz
karlooz's Avatar
no need to do anything with the ecu. mine has been fine since day one.
i think you are right about the LWF relieving stress on the RMS. mine has not leaked and i have 99K miles on it.
Old 10-31-2007, 08:39 PM
karlooz
karlooz's Avatar
the aasco unit has a friction surface that can be replaced.
Old 10-31-2007, 08:49 PM
washington dc porsche
washington dc porsche's Avatar
Hmm, so that's what it looks like. You probably should have purchased the Plenum
UCrazyKid
UCrazyKid's Avatar
The RMS issue is a weight thing, not vibration as I understand it.
Old 10-31-2007, 09:57 PM
ArneeA
ArneeA's Avatar
You're going with a single-mass LTW flywheel mated with factory clutch kit? Any reason why aside from not wanting your left leg to be larger than the right leg?
Old 11-01-2007, 12:18 AM
Steven C.
Steven C.'s Avatar
The only reason to change to a stiffer pressure plate is if he is adding torque...which a lighter flywheel doesn't do?
Old 11-01-2007, 12:52 AM
ArneeA
ArneeA's Avatar
The stock clutch hub is rubber. Aftermarket clutch hubs are sprung hubs.
I'm curious to see how the aftermarket single mass LTW flywheel works with the stock clutch (rubber hub) and PP.
Old 11-01-2007, 01:26 AM
nosub
nosub's Avatar
The clutch kit is this one: http://e-partssales.com/Merchant2/me...y_Code=996main
The box the LWFW came has a label which says:
"CAN BE USED WITH A SPRUNG CLUTCH DISC"
I spoke to AASCO and was told that they had modified the design from the original and that it would work fine with the OEM clutch. I was told this as well by Suncoast. Hope all goes well, will post pics of the OEM clutch with the LWFW as soon as the clutch arrives on Friday. <FINGERS CROSSED all goes well and play nicely together>
EDIT:
Wanted to show the clutch so all can see it is sprung.
Old 11-01-2007, 01:54 AM
ArneeA
ArneeA's Avatar
Yeah! It is a sprung hub. HMM. I'm curious to see what your impressions are with AASCO and stock clutch.
Old 11-01-2007, 09:11 AM
pat056
pat056's Avatar
Any idea what the weight savings is? Actual vs. advertised?
Quick Reply: A thing of beauty... AASCO Lightweight Flywheel
