996 Forum 1999-2005
Custom Supercharger and FVD tuning
Old 11-09-2007, 02:35 PM
  #106
Mother
Mother's Avatar
JEZZ Tippy you're no fun, it's not what I will learn but is also what you will learn. Little grumpy today.
1999 I did blow the MAF so I stuck in my other used one and I am back at idle and reading 1.37 - 1.44 V fluctuating.
At 6200 rpm and 4.6 V seems still to high if redline is 6800 this would put me over 5V I think and maybe causing the MAF failure?
My belt is 92.5" and seems really tight, I think I only have 3/4 inch left on tensioner till maxed out. As a note the belt actually did not break but split a couple of ribs on the inside closest to the SC and shredded off.
FVD now wants my stock ECU file to mod and are going to clean up the low end stumble.
Old 11-09-2007, 02:39 PM
  #107
Mother
Mother's Avatar
Originally Posted by redridge
excellent progress Mother... youve come a long way! Your MAF might be toast.
Good call redridge MAF is toast. New one in and all is ok.
Old 11-09-2007, 02:57 PM
  #108
1999Porsche911
1999Porsche911's Avatar
I don't see how it is possible to have a 92.5 inch belt if it is connected to all accessories. Depending on SC pully size, you should have a 103 - 103.7 inch belt. Too tight and you are going to fry your bearings.
Old 11-09-2007, 03:12 PM
  #109
Mother
Mother's Avatar
The package says 93 1/8" but I measure it at 92.5', my question is what are you doing with the extra, running a cappicino machine? I think that the tensioner sets how tight the belt is and not the size of the pulley. As long as I am not reaching the tensioner limit travel during WOT I'm ok, but at present I do not know how much it travels. Our systems are different and I imagine this accounts for belt size difference.
Old 11-09-2007, 03:35 PM
  #110
redridge
redridge's Avatar
Mother, whose SC bracket are you using, did you make your own? how many pullies are on there?...
Old 11-09-2007, 03:51 PM
  #111
Mother
Mother's Avatar
I modified a Ford Cobra SC bracket and just using one pulley on the sc and none on the bracket, mine pulley goes directly from the SC to the Alternator. Come to think on it my injectors are Ford Racing Bosch. Should have called it Cobra Gulf V1?
Old 11-09-2007, 03:58 PM
  #112
1999Porsche911
I modified a Ford Cobra SC bracket and just using one pulley, mine pulley goes directly from the SC to the Alternator. Come to think on it my injectors are Ford Racing Bosch. Should have called it Cobra Gulf V1?
Make sure you do not have to much belt vibration. Such will cause your belt to fray and split. Best to keep free lengths of belt to a minimum.
Old 11-09-2007, 04:16 PM
  #113
Mother
Mother's Avatar
I agree, I have only 4" between SC pulley and Alternator pulley center to center. I'll keep an eye on it. What is your take on the MAF Voltage @ WOT.
Old 11-09-2007, 04:21 PM
  #114
1999Porsche911
I don't think you fried it due to voltage spike unless it was going bad to begin with. What size pulley are you running?
Old 11-09-2007, 04:25 PM
  #115
Mother
Mother's Avatar
3.3" pulley and forgot to mention that the resistor wiring was fine and checked continuity through plug which was good.
Old 11-09-2007, 04:39 PM
  #116
1999Porsche911
The resister you are running should be fine.
If you want, double the ohms of the resister.
Old 11-10-2007, 05:18 PM
  #117
Tippy
Tippy's Avatar
Nah, I am not grumpy, just know what could happen with a hard lean.
On the belt tension side, you could use a cable tension tool that measures force on cables and check what your belt is and what a factory 996 belt tension is. Not sure if there is enough room to get the tool in there though? Just a thought.
Too bad you cant run a cog system, there is a place called ASP who make custom pulleys. With the cog set-up, you can run lower belt tensions, I loved my set-up, zero belt slippage around the S/C pulley. Probably too impractical for the 996, but keep them in mind for other pulleys you may need, they are cheap. GL, Tippy
Old 11-10-2007, 06:01 PM
  #118
Mother
Mother's Avatar
Sorry for the misunderstanding, I meant I was grumpy. I'll keep the cog sys in mind if I find that I am slipping, my brother used it on his blown 56 corvette with success back in the day.
Old 11-10-2007, 06:43 PM
  #119
1999Porsche911
You won't be pushing the compressor enough to need a cog system.
Old 11-10-2007, 07:54 PM
  #120
Tippy
Tippy's Avatar
True, I was talking about lower belt tension.
I was running a Vortech S-trim about 2-3 thousand RPM below max impeller speed (I think like 55,000RPM), thus needing the cog system.
Quick Reply: Custom Supercharger and FVD tuning
