996 Forum 1999-2005
Custom Supercharger and FVD tuning
Old 09-21-2007, 03:27 PM
  #31
Doug Donsbach
Doug Donsbach's Avatar
http://en.wikipedia.org/wiki/MAF_sensor
Old 09-21-2007, 04:32 PM
  #32
Tippy
Tippy's Avatar
Originally Posted by redridge
The maf works like this. There is a thermistor as a sensor, it is used to be heated, at a set (constant) temp. As air flows by it, it will cool... the computer tries to heat it up more since it wants it at constant temp. The voltage that is required to heat up the thermistor is proportional to the amout of air that tries to cool it. The varying heating up and cooling down is the signal of the airflow.
Ding, Ding...that is the magic answer I was looking for. Ok, that was what '99 was referring to as the MAF wire burning up.
Old 09-21-2007, 04:36 PM
  #33
Tippy
Tippy's Avatar
Originally Posted by Mother
I am assuming the resistor 1999 is referring to lowers the voltage for idle and allows more room (V) for extra airflow under boost with proper mapping.
That answers the other question I had.
See, this is different technology than how the American cars do it once you have exceeded the capability of the MAF. You simply got a bgger CFM one that matched the injector size.
Good stuff.
Old 09-21-2007, 04:46 PM
  #34
Mother
Mother's Avatar
Good stuff.
Missed that one Tippy
Old 09-21-2007, 08:55 PM
  #35
Mother
Mother's Avatar
Default Numbers
Curious which establishes the MAF ERROR is it the ECU or the MAF? Is it voltage, amperage or resistance it looks at? If the MAF/ECU has a operating range of 5V and the engine at idle with regular CFM flow *no boost" why are the data numbers showing rpm between 500-3000 and being within that range?
Old 09-21-2007, 09:17 PM
  #36
redridge
redridge's Avatar
the maf range is 0-5v, at 2.5K rpm you are already past mid scale of the maf. This is what 1999 is saying. it looks like you need to lower that signal so it will match 0-redline rpm = 0-5v.
I have to open up my air intake and see if evo have baffled the maf somehow so it will see lesser air flow, maybe this is how they done it instead of the resistor.
Old 09-21-2007, 09:47 PM
  #37
Tippy
Tippy's Avatar
Mother, ok that sounds weird, I honestly think you are beyond this board. Like I posted earlier, there are a lot of EFI tuners on the 911 turbo board. There is a bunch of guys who tune by laptops. They tune by the 02 sensor and EGT from what I have read.
'99 and redridge probably will throw in more theories but I think it is time to haul the enigne to a dyno and have GIAC professionally tune. There isnt any tuners on this board, or at least I have never heard anyone talking on that level. If there is, they should of stepped up by now.
Everytime this is discussed, I think of this time about 12 years ago when this professional drag racer (leaving his name out) here thought he could lean the motor to get more power. He just learned DFI (Digital Fuel Injection) and typed in a few keystrokes on the keyboard and on his next pass, bam!!!! 1800hp motor blown into bits. Hope this doesnt happen to you.
Old 09-21-2007, 10:55 PM
  #38
Mother
Mother's Avatar
Default maf
I would appreciate that redridge (Is yours supercharged?) EVO says that the system can returned to stock but if they spliced into the harness for the resistor then that differs from what they advertise. If there is a resistor which color wire is it hooked up to?
Old 09-21-2007, 11:10 PM
  #39
Mother
Mother's Avatar
Tippy, Having this thread and input from you and others helps the person making these mods in the future. I agree I have blown my fare share of engines in the past and am trying to approch this with some caution. FVD is doing my tuning as we speak there german engineers will be back Monday and we will go from there slowly as they put it. What's nice is they take your suggestions and listen and I like that, rather then we know it all.
The first step is get it to idle at my house so I can leak check etc etc... Then when ready take it to a dyno for the fine tuning it is costly for dyno runs $100 an hour or so.
Old 09-21-2007, 11:16 PM
  #40
Tippy
Tippy's Avatar
Sent you a PM
Old 09-22-2007, 05:52 PM
  #41
Mother
Mother's Avatar
Default Replied to PM
Sent you a PM
Replied to PM
Old 09-23-2007, 09:11 AM
  #42
1999Porsche911
1999Porsche911's Avatar
Don't forget that airlfow is dependant on throttle position. You can a have high MAF signal at low rpm as well as a low signal at high rpm depending on what you throttle is doing.
Old 09-23-2007, 10:36 AM
  #43
Ubermensch
Ubermensch's Avatar
I really don't believe that burning out the MAF is a concern. Maxing out the voltage (due to high airflow) is a concern but not because of buring the wire out. The concern is that you are the uppper end of a sensors range (and possibly beyond it). This means that you're supplying more air than the ECU knows how to compensate for and you will either throw a code or start running lean. The current through the MAF wire is limited by it's intrinsic resitance and the maximum 5V that will be supplied to it. Granted, if you let it sit a max voltage and therefor max current it will have a shorter life (as 1999 pointed out), but this is a secondary problem in comparison to the potential for running lean and destroying your engine. 1999's suggestion of placing a resistor in the circuit will lower the current should work to prevent that problem but I just don't think it's that big of an issue. My additional concern with this method is that you're changing the output from the MAF which would then have to be adjusted for in the EFI tuning. If you're maxing out the maf sensor I'd change sensors.
Old 09-23-2007, 12:47 PM
  #44
Mother
Mother's Avatar
Default Throttle
According to the readings I am not maxing out the voltage but they seem erroneous with low throtttle applied. I suppose that if the ECU is calibrated to receive so much fuel at a given votage and throttle angle then it should run either rich or lean depending, but it does neither it hunts.
Old 09-23-2007, 06:04 PM
  #45
1999Porsche911
Mother. On your chart, what are your airflow figures representing?
Quick Reply: Custom Supercharger and FVD tuning
