996 Forum 1999-2005
A/C Control
Old Sep 6, 2007 | 07:44 PM
plafra's Avatar
plafra
2nd Gear
Default A/C Control
I have an 03 996. The A/C Control LCD is starting to bleed out on the screen. Anyone else have this problem? Any suggestions to repair or replace. Thanks.
Old Sep 6, 2007 | 09:05 PM
Dutchie in NC's Avatar
Dutchie in NC
I have the same issue... 03 as well
Old Sep 6, 2007 | 09:08 PM
Dharn55's Avatar
Dharn55
Mine bled and was replaced under warranty. Nothing you can really do if an LCD goes bad but replace it. You see the units on Ebay on a regular basis at way below dealer cost. I think I remember seeing a post on replacing the LCD instead of the whole control on one of the Pcar sites, either here, Renntech or 6 spped online. You might try some searches. Replacing the unit itself is a simple 15 minute job.
Old Sep 6, 2007 | 11:02 PM
Tool Pants's Avatar
Tool Pants
Jurichar's instructions on how to replace just the LCD display are somewhere, but I know for sure they are Renntech.
http://www.renntech.org/forums/index...c=15193&hl=LCD
Old Jan 4, 2010 | 03:39 PM
PostVW's Avatar
PostVW
Cruisin'
An old item but -I need to replace my broken/bleeding LCD A/C-panel on my 986-Boxster from 2004.
My question: Is the Audi-display compatible with Porsche? Does it look the same?
Check this link: http://cgi.ebay.com/ebaymotors/Audi-...item414bc1a764
Regards
Kenneth -Boxster owner in Sweden
Old Jan 4, 2010 | 04:52 PM
Tool Pants's Avatar
Tool Pants
Link is not working. There was a company on ebay that had the led, but it was listed for Audi. It worked but was a bit too large. The company then came out with a small unit for 986/996. Someone on renntech used it and it worked fine.
I think this is the website for the company that was/is selling them.
http://www.modulemaster.com/en/servi...e_controls.php
Old Jan 4, 2010 | 05:00 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Tool Pants,
It is great to see you back here on the 996 Forum! It has been quite a while!
Old Apr 19, 2014 | 09:27 AM
frisbee91's Avatar
frisbee91
Update for posterity:
If you want the original factory look. I'd highly recommend this...
http://shop.914rubber.com/LCD-Produc...m1plqscsfapp06
The guy at 914Rubber.com makes replicas of the original LCD displays. They are perfect, I have one in my car. (which is why I have a spare Audi display)
