996 Forum 1999-2005
Interior carbon renewing
Old Jul 23, 2007 | 02:39 AM
ag9v's Avatar
ag9v
7th Gear
Default Interior carbon renewing
Tried searching without success...
My 2000 996 came with these carbon package options:
XMJ REAR SECTION OF CENTRE CONSOLE IN CARBON
XNR CENTRAL AIR VENT MOUNTING IN CARBON
XNX TRIM STRIP IN CARBON
XPY INSTRUMENT SURROUND IN CARBON
The sun has taken its toll on the carbon which is becoming cloudy at the center air vent as shown in the attached pic. The center console and ash tray are also showing considerable cloudiness.
I would like to go back to the carbon fiber if I can get rid of the unsightly cloudiness.
I have yanked out the carbon pieces for the time being and replaced them with different pieces. Doing so has given me the luxury of time to approach this project the right way without rushing. I was hoping someone here has had experience with restoring the epoxy back to original condition and could help me get started on this latest project of mine.
TIA
File Type: jpg
Old Jul 23, 2007 | 03:08 AM
jury_ca's Avatar
jury_ca
Hmm, I'm not sure it can be restored.
Old Jul 23, 2007 | 03:18 AM
Jmakado's Avatar
Jmakado
I would start with a paint cleaner. For an off the shelf try Meguiar's Deep Crystal Cleaner (step 1). It's a very mild chemical cleaner. If that helps, follow with a polish then wax to help preserve the finish. You could go through the Meguiar's Deep Crystal 3 step system if you like.
If the Step 1 product doesn't have any effect the try an abrasive cleaner next. Meguiar's ScratchX is a great product off the shelf and works well by hand. If you have no luck with that then a machine applied polish would be your next step. I have had good luck using machine polish on faded carbon hoods. However, those usually have a gel coat finish, like a boat. So marine products work best with them.
The trim may be beyond repair, but it wouldn't hurt to try.
Good luck!
Old Jul 23, 2007 | 08:46 AM
nycebo's Avatar
nycebo
Lightbulb
It is a decidedly frustrating phenomenon. From what I recall, in earlier versions of their carbon fiber efforts, Porsche used an Italian company. Unfortunately, these parts clouded over time, turned a greenish hue, and ultimately cracked. Clearly, the sunlight accelerated this damage. Unfortunately, unless it's cracked you're out of luck with PCNA and a warranty replacement (if you're even still under warranty). In fairness, my CF steering wheel did have cracks and under CPO, PCNA dutifully replaced mine. I was ecstatic. Unfortunately, they did not view the cloudiness as a flaw, only as the sad signs of aging.
Consequently, I've been replacing them with parts from MACarbon. The pieces are pitch black and look fantastic. While they aren't inexpensive, they do cost noticeably less than OEM parts. Give John a call or an email and he'll steer you through the exact details of what you might be able to do to your existing parts, or what it'll cost you to replace them. He's a super guy all around. Indeed, I'm down to the last piece that needs to be swapped out: the 3-piece horseshoe surround. Good luck!
Disclaimer: I have not relationship the company; just one hell of a happy customer to save on replacement parts.
Old Jul 23, 2007 | 11:24 AM
Dale Gribble's Avatar
Dale Gribble
Pocket Sand
the clouding is the gelcoat ontop of the carbon fiber turning yellow. take it to a shop and have them wetsand it as far as they can go, then reclear it and it might go away...this might be diffficult with small interior parts tho.
Old Jul 23, 2007 | 12:05 PM
michael.s.under's Avatar
michael.s.under
nycebo, do you have johns contact info from macarbon....
Old Jul 23, 2007 | 12:09 PM
okbarnett's Avatar
okbarnett
The outer layer on these parts is actually a urethane clear coat, same as the body paint base coat / clear coat. So you can try having a body shop sand and re clear one piece and see if it corrects the problem.
Old Jul 23, 2007 | 12:21 PM
Benjamin Choi's Avatar
Benjamin Choi
I haven't noticed any effects yet and I have OEM carbon all over the interior. I do have an issue with the dash CF trim all the way up in the windshield vent area... coming undone due to the CF piece curling from the temperature changes.
Old Jul 23, 2007 | 02:04 PM
Gator911's Avatar
Gator911
Sand it down and reclear it...
Old Jul 23, 2007 | 03:37 PM
nycebo's Avatar
nycebo
You can email him at johnb@macarbon.com or call him at (650) 520-4822. He's a super guy and can tell you as much as you'll want to hear about OEM CF in the car and the impact of the sun. Good luck.
Old Jul 23, 2007 | 04:55 PM
michael.s.under
Thanks NYCEBO, just the info I needed, you rock!
Old Jul 23, 2007 | 08:34 PM
nycebo's Avatar
nycebo
Anytime.
