996 Forum 1999-2005
RSS PLENUM INSTALLED...0-60 TIMES
Old May 31, 2007 | 03:31 AM
  #61
Chuck Jones's Avatar
Chuck Jones
This is on the 99 996 and maybe other models as well.....Just watch out when you take the old plenum out and start messing around with the rubber boots on each side...they each have a small black tube that runs from the bottom of the boot back into the engine compartment. I'm not sure what they go to, but you can break them if you try to pull out the boots. After you get the old plenum out, look into the boots and you'll see the rubber tube sticking up in there. It's not that bad of a deal really....couple hours for a novice is all you need...and be patient wiggling the plenum in and out.
Also....did you folks see the RSS notice about the length of the four OEM 10mm bolts that hold the plenum to the throttle body? The OEM bolts are too long for the depth of the tap on the new plenum, and you need to use a couple of washers to keep the bolts from bottoming out. RSS is going to be sending out shorter bolts with the new kits. I just used a stainless 10mm washer stacked on a lock washer to take up the slack. If this info is a repost or has been previously mentioned here, I apologize.
BTW...for you folks who know Mfletch...or Mark...he went into some pretty serious back surgery today and was under the knife for about 7 hours....I'll be going to see him when he gets out of his morphine high.
Old May 31, 2007 | 03:36 AM
  #62
rountreed's Avatar
rountreed
More info is better, Thanks!
Old May 31, 2007 | 06:38 AM
  #63
jeff_c's Avatar
jeff_c
I have a '01 C4 and it took me about 45 minutes to do this install. For me the trick was loosening the hose clamps almost all the way and taking the two that were closest to the plenum off and sliding them onto the plenum before sliding the plenum in there. This allowed the two boots to flex more on both ends so I could push them all the way to the outside and allowed me to gently pry them further apart in the front (making enough room for the plenum to just slide in from the front at no angle. I didn't see the warning about the bolts but mine fit perfectly as is.
Haven't really had time to drive the car but within the first 30 miles after install I also notice the smoothness that others have noted.
hth
Jeff
Old Jun 10, 2007 | 11:44 PM
  #64
Ed Newman's Avatar
Ed Newman
Found the manufacturer's site.... http://www.innovativeprodesign.com/
Lots of good info inlcuding air flow test results for the intakes.
Bad news it that I don't see one for the GT3.
Old Jun 10, 2007 | 11:51 PM
  #65
user 597208234's Avatar
user 597208234
Yet.
LEP 2002 C4S Coupe
Old Jun 11, 2007 | 05:26 PM
  #66
Dr_KarlB's Avatar
Dr_KarlB
This is really interesting.
The stock unit flows 829 CFM
So how much air does the engine need ?
Assume a 3.6 lt. Its a four stroke engine (duh!) so the cylinders take in air every second crank rotation.
At redline (7500RPM) there are 3750 intake gulps per minute
Or and air flow of 3.6lt x 3750 = 13500 lt/min
This translates to 476.75 CFM
So the stock unit seems to allow almost 2x the max required airflow at redline.
Old Jun 11, 2007 | 07:21 PM
  #67
Tippy's Avatar
Tippy
And thoses numbers (if you are correct) would be at FULL cylinder filling which is NOT possible with the induction, valvetrain, and exhaust the 996 has configured.
It is interesting that in the carb world, this always was the case also. Putting a carb with an airflow higher than what the "numbers" required gave you a little more peak hp over the "ideal CFM" the engine theoretically (sp?) needed.
Old Jun 11, 2007 | 08:21 PM
  #68
Dr_KarlB's Avatar
Dr_KarlB
Its probably not just airflow but pressure drop.
If you had infinite compression ratio, then in the cylinder you would have zero PSI and atmoshpere is approx 15psi, so you need to fill the cylinders to a max of atmospheric pressure with a 15 psi pressure. any drops along the way would give you a less than full filling of the cylinders with air.
But if you calculate the pressure drop thru a 3" tube (like the inlet system) at the flow rates we have, its quite small (like .5PSI).
Obviously i have no idea where the major restrictions in the system are, but i would guess the valves (95mm bore ?? and 4 circular valves so they can be so big, and have a limited lift).
Anyway, this is really about tuning the pulses at this point isnt it... the inlet isnt smooth as the cylinders "suck" air for only 1/4 of the time and with 3 per side, the air flow is zero for at least 1/4 of the time on each bank... the air also alternates side to side doesnt it ??
Clever engineering can make use of the pressure resonances to make a very efficient system and certain revs
Old Jun 11, 2007 | 09:14 PM
  #69
Tippy's Avatar
Tippy
I know changing the firing order of a Big Block Chevy nets some major hp gains. This is probably the theory you are talking about.
Old Jun 12, 2007 | 08:44 AM
  #70
nycebo's Avatar
nycebo
Thumbs up
Very interesting analysis Karl. I wonder if getting the air faster means that the car can sprint faster though, even if it doesn't need the full 'gulp' that the plenum can provide. Or, are we running into a law of large numbers issue where adding more results in the topping of a logarithmic rather than exponential curve. In other words, each added unit results in extremely small and potential immeasurable increases in performance.
