996 Forum 1999-2005
Brake Pads
Old May 23, 2007 | 09:11 AM
pat056's Avatar
pat056
Default Brake Pads
It's time to change on the 996. I would like to but on some more agressive pads. I can tolerate some noise, but don't want to wear out my rotors. I won't be tracking this car.
Any suggestions? I've had good results w/Hawk, but thought I'd get advice from any experience you guys might have had.
Old May 23, 2007 | 09:29 AM
Steven C.'s Avatar
Steven C.
More aggressive means more dust and these type of pads are easier on rotors since they are generally softer which means they will not last as long as a standard duty pad. Is this OK for you?
Old May 23, 2007 | 10:26 AM
pat056's Avatar
pat056
Steven C.
More dust is OK as long as it's not like PF pads where the dust + water = a non-soluble product that won't come off paint.
I baby my 996 and clean/wax the wheels regularly and wide them off almost daily.
Old May 23, 2007 | 11:43 AM
aben8057's Avatar
aben8057
Pat,
If you are not going to track the car and just use it on the street, why not go with OE or a softer compound?
Old May 23, 2007 | 11:57 AM
pat056's Avatar
pat056
Aben8057:
I always like to feel like I'm improving performance when replacing OE...even if it's just a little bit. I noticed on Tirerack they have Hawk ceremic (supposed to be somewhat improved over OE) and composite (supposed to be much improved over OE with minimal increased dusting).
Any thoughts/experience? Is ceremic the OE compound?
Old May 23, 2007 | 12:35 PM
MikeRosen's Avatar
MikeRosen
A change to a more aggressive pad may not have any effect on your stopping power on the street. In the case of a 996 Porsche used only on the street, you have way more braking power than most any other car even with the OE pads. It is unlikely that you are heating them up enough to cause fade. I'd stick with OE if it's cheaper and consider improving your stopping power and handling by putting the money saved towards your tire budget when the time comes.
Old May 23, 2007 | 01:04 PM
Benjamin Choi's Avatar
Benjamin Choi
Any ones you guys can recommend that provides little to zero dust for a street 911, yet still balances out with similar to OE stopping power?
Old May 23, 2007 | 01:05 PM
MechanicalEng's Avatar
MechanicalEng
What about the Porsche High performance pads?? has anyone tried them??
Old May 23, 2007 | 01:06 PM
aben8057's Avatar
aben8057
Benjamin....Mintex red box
Old May 23, 2007 | 02:31 PM
Steven C.'s Avatar
Steven C.
Hawk HPS Great pad on both of my P Cars.
Old May 23, 2007 | 02:37 PM
Macho Belly's Avatar
Macho Belly
+1 on Hawk HPS if low dust and similar performance to OEM is a goal. I had Hawk HPS on previous Boxster S. Now using Pagid Sport on 996 since I'm doing some DEs.
Old May 23, 2007 | 03:29 PM
pat056's Avatar
pat056
just ordered Hawk HPS...thanks for all the info!!
Old May 23, 2007 | 04:30 PM
Benjamin Choi
For the C4S do I have to do any mods to the Hawk HPS pads? I remember reading something somewhere about this....
Old May 23, 2007 | 04:58 PM
Steven C.'s Avatar
Steven C.
Yes, for both of you guys you will need to drill a small hole in each pad for the wear sensor to plug in. Very easy and self explanatory once you see the pad you remove.
Old May 23, 2007 | 06:20 PM
jakermc's Avatar
jakermc
Hawks can be a bit tougher on rotors than other choices. I use Porterfield R4S on the 996 and F-car. Not compatible with the brake wear sensors without drilling holes but I just tired them off. I pull the wheels often enough to not need a sensor.
