X73 is in!!!
#31
Originally Posted by deputydog95
weird. i know somebody who just put this setup on their turbo. just about 26" flat front and rear, with it being ever so slightly lower in the back.
#33
Ok. Sunny day, but still cold at 30 degrees. Decided to take the C4S out to the office anyway and took pics. I know, I need to detail the tires and the trim, but it's too darn cold.
#34
Newbies Hospitality Director
![](http://members.rennlist.com/palting/100-0012_IMGsm.JPG)
#36
Thanks, Tim. I think the X73 is the best mod for looks and performance. And I haven't even taken it to the track yet.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#40
I suppose you could order it separately. The part number specifically for the engine mounts for the X73 is "996 375 049 90". It comes as part of the kit, though, and I find it unusual that the original owner would not put it in. Why don't you make sure? First, check that it is the X73, and not some other suspension. Take a look under there, and the spring/shock assemby should be bright yellow. If it's bright yellow, then it is likely the X73. Unfortunately, the engine mounts look identical to the stock mounts. You'd have to get the tech to check the part numbers to make sure you do or don't have the X73 mounts.
You do have a C4S or a TT, right?
