996 Forum 1999-2005
03 996 cab minor noise
Old Feb 4, 2003 | 11:16 AM
AnthonySp's Avatar
AnthonySp
Question 03 996 cab minor noise
I just bought an 03 cab and notice that there appears to be a pretty constant noise between the door and dash on both the driver and passenger sides. Almost like the plastic from the dash and the door rubbing together. It is pretty annoying. At first it sounded like the AC vent was rattling but I don't think that is it.
Is there a fix for this?
Also what is the cheapest place to order tequipment stuff from? Is the windstop any good?
Thanks in advance.
Old Feb 4, 2003 | 12:07 PM
DonW-Cape Cod's Avatar
DonW-Cape Cod
R.I.P.
Lifetime Member
Post
Can't address the noise or tequipment question, but the windstop does work very well. IMHO, it's worth the money. With top down, windows up and screen on it's very quiet and very little wind!
Old Jan 6, 2018 | 10:54 AM
Pseudo Nim's Avatar
Pseudo Nim
Holy thread revival - but did you, or anyone else, ever figure this out? I have _exactly_ this noise and I tried taking the vents out - didn’t help. Where is it coming from?!?
Old Jan 6, 2018 | 12:25 PM
fpb111's Avatar
fpb111
Noise only while driving, or always with engine running? Stock speakers? Stereo noise? Even when off the amp can pickup emi. Pull some fuses.
Old Jan 6, 2018 | 06:25 PM
Pseudo Nim's Avatar
Pseudo Nim
While driving and not always. Depends on RPMs and road surface. I found sometimes if I jam my hand hard between the AC vent and the door, I can occasionally make it less bad.... won’t go away though, otherwise I’d just drive one handed
Old Jan 8, 2018 | 01:28 PM
mrjonger's Avatar
mrjonger
Just FYI, it's easier to just search on google vs the RL search function
https://rennlist.com/forums/996-foru...from-door.html\
https://rennlist.com/forums/997-foru...le-solved.html
There's more stuff on Renntech and other forums
Old Jan 8, 2018 | 01:36 PM
Ponchobroke's Avatar
Ponchobroke
Try the plastic cover plates on the top latching mechanism above the mirror. They drove me nuts for a while.
Old Jan 8, 2018 | 02:36 PM
RSBro's Avatar
RSBro
My SatNav unit does this endlessly. Was going to put off a replacement amp and unit until later this year, but it's almost unbearable.
Old Jan 8, 2018 | 09:00 PM
Pseudo Nim's Avatar
Pseudo Nim
Thanks! Good idea, lol. I'll go troll those threads too.
Hmm. You mean the mirror controls? Not sure what you mean by the top latching mechanism? It does feel like it's coming more from the mirror section than the vent section, though...
Old Jan 9, 2018 | 12:56 AM
Ponchobroke
The convertible top latch that hooks above the mirror. It has two plastic filler panels about 1.5in x 4in on either side.
Old Jan 11, 2018 | 10:21 PM
craigmakes321's Avatar
craigmakes321
headlight switch in my '03 squeaks against the dashboard hole where it is inserted. Drives me nuts. Lots of squeaks in the dash if it is cold - as car heats up the plastic expands and stops making so much noise.
