Peace at Last........dash rattle solved!
I have had the most annoying rattle that sounded like it was coming from the passenger side of the dash around the airbag, speaker,vent area. It could be clearly heard when going over rough pavement and sounded like a plastic on metal vibration. Rattles drive me nuts, and no matter how hard I try, I can't tune them out. I set out determined to solve it one way or another. First I had a friend drive while I sat in the passenger seat to make sure I could locate the region the sound was coming from. (I was convinced it was the passenger area of the dash and sitting in the passenger seat reaffirmed my conviction.) Next I read every rattle thread on Rennlist (quite a few here by the way). Once you read the threads, you realize that the rattles can come from anywhere and everywhere and also sound like they're someplace they're not. OK, I said to myself, grab a beer, and let's go for the process of elimination method by slowly taking things apart and out of the car. First up was the cup holder. Two annoyingly painstaking allen bolts and it slid right out. Went for a drive around the block...........still there. Crap! I was going to dismantle and remove the glove box next, but recalled a thread in which Edgy had mentioned that he once had a rattle years ago that turned out to be a hard line of some sort that came loose from its bracket behind the wheel well liner. Since I wasn't in the mood to tackle the glove box, I thought I might as well remove the front wheel and liner to see if by chance anything was loose. Lo and behold, an aluminum tube (must be associated with the A/C or engine coolant) had a retaining bracket that had come off its mounting position. I had a glimmer of hope and called my wife to jiggle the line while I leaned inside the car to see if it sounded at all like the rattle. Bingo! Mounted it back in position, put everything back together and test drove..........problem solved................Nirvana at last.
Below are a few photos of the line and bracket. The first photo just shows the location of the line. The next two show the bracket out of position and I then show the bracket clipped back in place. (Also the last one shows some gravel in and around my suspension from my "off road" excursion when the rear end stepped out last year.) In case anyone else has an annoying "dash" rattle that cant be solved, this may be worth looking at. Thanks Edgy!
JEHolloway (05-24-2020)
Thanks for sharing. I have a creaking sound in the driver's side of my cab that sounds like it emanates from very close to the top dash area next to the A pillar. I've removed A pillar cover as well as trim at back of dash by windshield, but noise persists. Dealer listened to it and didn't know what it might be. They said they could spend time to look for the cause, and if they find the cause and it doesn't appear to be related to my modified suspension (Damptronics), the warranty will cover it. If deemed to be a result of my modified suspension, I pay for it. It sounds like a plastic panels creaking against another panel.
Question: Is there a similar bracket on the driver's side that could be causing this? Since mine isn't a rattle, I suspect it is not the bracket, but just wondering if I should check before taking to dealer this week.
There is also a possibility that you have a rattle behind the glove box. I found this article on Planet-9
http://www.planet-9.com/reviews/misc...nt-2fdash.html
Mine was the seatbelt rattling against the seat hard back - DOH!
I read forums all the time to help guide me when I have issues. This is one of the first times I am actually posting. I must say I LOVE you guys!!!!!! Everyone who takes the time to post on here is amazing!! I had this same exact problem. I have a 2002 C4S and it is soo embarrassing driving around with passengers while this rattle is going down.
Thank you, thank you, thank you!!!!!
Fuse cover gadgets
My post was 12 years ago, and I sold the car 9 years ago. Not sure how this thread got resurrected.
