fun weekend project - pep boys muffler bypass pipe
#48
any one in So Cal LA area have this done? I would be interested in hearing how this sounds. Sounds like a quick mod...wow.
If I did'nt already have mufflers I may have to try this!
#49
Here's the result of my muffler bypass project. I didn't want to throw down 6 bills or whatever it is currently for the Fabspeeds, but have decided I want 40-50 lbs less on the car at the track, so I ordered two 90 degree stainless steel mandrel bends from Summit Racing and two Magnaflow polished stainless double wall round tip (both in 2 1/4") took them to a muffler shop and had them barely flare the end that goes onto the cat and weld the tips on(not a great job on the welding). I finished them with the angle grinder with 3M scotchbrite velcro pads and voila.... two pounds a piece and a total of $140 all told. So you can get something nicer than the Pep Boys version without too much trouble.
#50
Nice! It's amazing to see how much things are overpriced.
I am interested to see if a glass pack muffler could be plumbed in there somewhere to help control the sound.
I think going open will be too loud for me.
thanks,
Amir
thanks,
Amir
#51
I toyed with the idea of using a glass-packed tip like the one's Monza make, but don't like their look so much and I'd imagine they're a bit heavier and that could be a problem as the bypasses are unsupported.
#53
#54
Hmmmm.. Glass packs. Not sure if they make them in large enough diameter, but you could get some baffle inserts for motorcycle drag pipes. Harleys old Triumphs etc... They are metal baffle inserts that have a set screw to secure them. You can also wrap them with fiberglass mat to mellow the sound. If I get some time this winter I'll make some up as I've got some extra baffels from my 72 Bonneville that I'm not using.
#55
Originally Posted by Phokaioglaukos
How would the 90 degree bens look by themselves? Did the tip add much to the appearance? (This would be an "at the track" change for me, so appearance is not high on the list.
#56
A couple things. Forget Supertrapps. We tested them on my racecar in hopes of getting back some of the torque we lost when we went to straight pipes. I'm not sure I still have the dyno charts but it was terrible. We lost a ton of hp and torque. The quality was just as bad.
Don't forget to add some sort of set screws to keep your pipes from falling off at the track. This is covered somewhere in this thread.
Finally, for the track, I think going tipless is the only way to go. You'll never find a race car with tips.
Jim
Jim
#58
Originally Posted by penguinking
supertrapps don't work? i see them on plenty of race cars though - or do most do that so they can make the sound req's at the track?
#59
Jim
Jim
It's hard for me to see how a set screw would be more secure than a robust (1" wide with a 12mm bolt) exhaust clamp. Maybe I'm missing something here?
When my car becomes a race car I'll remove the tips.
#60
I thought the discussion about set screws was to keep the tips from coming off.
When my car becomes a race car I'll remove the tips.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I hear you on the tips. For a street car I'd do the same. If you're only using the pipes on the track I'd skip them though.
I'm certainly not saying that you shouldn't use an exhaust clamp. I'm just warning that the combination of different metals (stainless and plain steel), changing temps and the weight (espeically with tips) vibrating with no support can cause them to come loose. We solved the issue with set screws.
Jim
