Yet another spoiler thread in the weeds
Subscribe
Mar 16, 2026 | 09:39 AM
Looking for some guidance on troubleshooting my electric spoiler on my 996.2 Carrera 2. I've made some progress in that the spoiler control light only comes on when the spoiler tries to go up. so far down the rabbit hole a bit so here is what I know:
  • I removed disassembled and regreased everything in the plastic assembly
  • The plastic tracks seemed to be uneven so now they are fixed and located correctly for the micro switches
  • Fuse D7 is good, both relays test good
  • There is 12v at both relays and I attempted swapping them around
  • With a power probe from the connector I can manually raise the spoiler
  • Using the manual switch by the fuse panel, once the spoiler is up from the above step I can lower it just fine
  • Hitting the right speed or using the manual switch triggers the spoiler control light and the spoiler does not move, nor do I hear any noises from the motor
I'm stuck as where to go next, my gut says the issue is between the raise relay and the connection behind the passenger tail light, but I'm not really sure the best way to access. Any advice or thoughts?
Reply 0
Mar 16, 2026 | 11:56 PM
Have you checked the “up” wiring at the switch? Or tried putting power to it there?
Reply 0
Mar 17, 2026 | 05:28 AM
The micro switches may be bad.
Reply 0
Mar 17, 2026 | 10:08 AM
Quote: Have you checked the “up” wiring at the switch? Or tried putting power to it there?
It's the same behavior if I manually jump it, at speed I also get the spoiler control fault when it's trying to raise. Up requests don't seem to send any voltage.
Quote: The micro switches may be bad.
I initially thought this, but after reassembling the down function seems to work and stop correctly (they were misaligned when I initially pulled it apart). Do we know where the "logic" happens from the microswitches? It doesn't even attempt to start when trying to go up.
Reply 0
Mar 17, 2026 | 11:13 AM
That's my question too. What tells it when to go up at speed or retract at lower speed? Mine also works fine manually. I get a clicking sound when I slow down. Even if I do not hit extension speed. I have new switches to try.
Reply 0
Mar 17, 2026 | 11:23 AM
Quote: That's my question too. What tells it when to go up at speed or retract at lower speed? Mine also works fine manually. I get a clicking sound when I slow down. Even if I do not hit extension speed. I have new switches to try.
well mine goes down fine, but won't pop up using either the switch or the right speed driving. Both microswitches tested fine for continuity, but I want to understand where the microswitches come together with the other signals to say yeah raise that spoiler.
Reply 0
Mar 18, 2026 | 11:51 AM
Found this in another thread:
To be safe I swapped my microswitches last night (found some 3-wire cheapies on amazon), but the ones in the car tested fine as far as I can tell as well. Still in the same spot it seems, the spoiler won't raise. Maybe I just need a fixed spoiler.
Reply 0
Mar 19, 2026 | 09:57 AM
For anyone following along I have to some degree thrown in the towel after another couple of hours troubleshooting. I ordered a used mechanism with harness on ebay for a few hundred bones. I'm not crazy about this solution as I still don't feel I've 100% id'd the root cause, but I guess we'll see and I can at least sell the working bits from mine.
Reply 0
Apr 2, 2026 | 09:20 PM
Well after swapping a whole new assembly, I'm back in the same spot. Spoiler will go down, but not up. I dug in a bit more and I can manually trigger the extension relay using a power probe which does raise the spoiler. There seems to be an issue between the switch and the relay (or maybe the cluster?) open to thoughts if anyone has any. Otherwise I think I need to rip out the center console to get to the harness and see what's what.
The extension wire on the switch is green/red, but at the relay it's green/white does anyone know where it splices or transitions over?
Reply 0
Apr 2, 2026 | 10:26 PM
Also I can’t raise the spoiler with my durametric.
Reply 1
Apr 2, 2026 | 10:39 PM
Troubleshooting issues like this can be simple or very complicated....
The actual failure once found is always simple....a bad switch, and bad motor or a bad wire/connection .. Since you have tried a new switch and new motor, time to dig out a DVOM and test the integrity of the wiring....
You will need to use a systematic approach...ie.... each next step/test is determined by the results of the previous step/test......
Reply 0
Apr 3, 2026 | 12:06 AM
Quote: Troubleshooting issues like this can be simple or very complicated....
that’s where I’m at, not sure my pride will let a spoiler beat me. I am curious though if there is a cluster control module located somewhere
Reply 0
Apr 3, 2026 | 09:49 AM
Quote: that’s where I’m at, not sure my pride will let a spoiler beat me. I am curious though if there is a cluster control module located somewhere
The Spoiler Control Module/Logic is built into the Instrument Cluster to control the " Automatic Function",,, but it does not control the " Manual Function" ...
Reply 0
Apr 3, 2026 | 10:04 AM
Quote: The Spoiler Control Module/Logic is built into the Instrument Cluster to control the " Automatic Function",,, but it does not control the " Manual Function" ...
Right the "logic" is all in the microswitches. I need a full wiring diagram, but the 12v signal that comes from either the manual switch OR the cluster doesn't seem to be making it to the extension microswitch. The microswitch only has 1 common wire so I would think the manual switch and cluster have to merge at some point, this is where I would assume they might have separated or broken or something.
Lots of assumptions, I just need to trace the harness now I think.
Reply 0
Apr 3, 2026 | 10:21 AM
Quote: Also I can’t raise the spoiler with my durametric.
I called Durametric only to find that Durametric doesnt service the wing. They were very nice and sent me the same diagram you have.
Does the decision making happen in the inst. cluster or does the cluster gather the speed information and send it to ECM?
The logic is simple: at this speed the spoiler motor spins one direction. The motor changes direction at the other speed set point. There are only two speed set points. Hit 74ish spins to extend. Hit 35ish spins the opposite direction to close.
I had to walk away for a while. I too caught an assembly and now have two different sets of new switches. After I finish installing the stereo upgrade I will work on the wing again. Im following g this. Thanks for posting your frustration. I understsnd.
Reply 0
