996 Forum 1999-2005
996 PPI Question / Bore scoring
Old Apr 13, 2025 | 07:23 PM
TTownThomas's Avatar
TTownThomas
anybody know if these marks in cyl 6 are anything to be concerned about?
Old Apr 13, 2025 | 08:36 PM
silver_tt's Avatar
silver_tt
They are not very good photos since they are only showing you a small section of each cylinder but I don't see any scoring in what you have posted. The squiggly line in cylinder 2 is not a crack but rather just a normal mark in the casting.
Old Apr 14, 2025 | 08:26 AM
TTownThomas
I did not even pick up the casting mark. Thank you for looking at them
Old Apr 14, 2025 | 09:06 AM
Mike Murphy's Avatar
Mike Murphy
Looks good to me
Old Apr 14, 2025 | 10:03 PM
TTownThomas
PPI was today.
Has these codes: ~Alarm System codes: ~60 Central locking limit position lock not reached. ~54 Radio receiver faulty. ~33 Passenger compartment monitoring sensor.
Has a leak they suspect is from the rear main seal. Nothing else significant of note. Obviously an RMS is a big job, relatively speaking, and was done 4 years ago.
Old Apr 15, 2025 | 08:36 AM
GC996's Avatar
GC996
I wouldn't worry much about the RMS. It's not a catastrophic part that you gotta replace. Quite frankly, it will probably leak less if the car is driven more frequently. The pictures you posted of the bores look good. Besides the codes you posted, what about the rest of the PPI? Suspension, exhaust, powersteering, cooling? What needs to be replaced?
Old Apr 15, 2025 | 09:34 AM
ZuffenZeus's Avatar
ZuffenZeus
Originally Posted by TTownThomas
PPI was today.
Let me guess, it has an aftermarket radio installed?
Old Apr 15, 2025 | 11:48 AM
TTownThomas
Yessir!
Old Apr 15, 2025 | 01:51 PM
ZuffenZeus's Avatar
ZuffenZeus
BINGO!!!
The alarm has an open circuit at the radio level. This is because of the alarm wire that was clipped to the Becker radios. If dismounted, it will trigger the alarm and give DTCs. One you find the alarm wire, cut the connector off and insulate the wire. The car will be happy again.
