Ticking noise from engine
Hi all, the last few times I have driven my 911 I have noticed the ticking noise shown in the attached videos.
it only started happening when we began to get colder weather.
is this something I should be concerned about or does anyone know if this is normal when it gets cold?
2000 Porsche 911 C2 Cabriolet w/Tiptronic. 115,300 miles
Thanks in advance.
Thanks in advance.
The sound in the first video? That’s the injectors, they’re supposed to sound like that.
i didn’t hear anything worrisome in the other two videos. Obviously it’s a cold start (as you can tell from water vapor from the exhaust), but it sounds normal to me.
RennTN (10-09-2023)
First car?! Good for you. Consider joining the Porsche Club of America and its local chapter. It will add to your knowledge base, plus there are a lot of PCA activities that make owning these fun and educational.
Luftundwasser (10-09-2023)
The gap between the exhaust and the rear bumper seems rather large, and more so on the driver side versus the passenger side. You should check your engine mounts. They might need to be replaced.
The following 2 users liked this post by binaryaudax:
Luftundwasser (10-09-2023),
Porschetech3 (10-09-2023)
Engine sounds good to me also, you just have the "996 jitters", and yea, you need new engine mounts...
The following 2 users liked this post by Porschetech3:
B-ran (10-09-2023),
Engine mount check. Get yourself on the ground eye level with the exhaust pipes you can see just below the bumper. If the pipes are not level left to right, you have an engine mount failure. It can be done in your garage, but you may need a 2 meter breaker bar. DIY video at FCP Euro.
Thanks in advance.
Thanks in advance.
