996 Forum 1999-2005
Opinions on downshifting
Old 08-25-2023 | 11:55 AM
Frankie V.'s Avatar
Frankie V.
Default Opinions on downshifting
Hello there, I guess it’s obvious but curious about downshifting and it’s wear and tear on clutch, gears, etc. Lots of people come to a stop light putting the car in neutral and using breaks, but I like downshifting in addition to breaks when necessary. This is normal street driving (not on a race course). Naturally I don’t come too fast into a stop light and need to downshift, but to me that’s part of why I have a stick! Thoughts?
Old 08-25-2023 | 11:58 AM
De Jeeper's Avatar
De Jeeper
Do it all the time and usually heal toe just for track practice.
The following 4 users liked this post by De Jeeper:
Frankie V. (08-25-2023), imhighlander (08-27-2023), wdb (08-25-2023), WillyDaP (08-25-2023)
Old 08-25-2023 | 12:00 PM
wildbilly32's Avatar
wildbilly32
To each their own. Our cars have very good brakes. I don't downshift when slowing for a stop light, but that is my choice. While sitting at a stop light it is recommended to put the car in neutral and release the clutch pedal.
Old 08-25-2023 | 12:01 PM
WillyDaP's Avatar
WillyDaP
Brakes .....heel and toe.........don't you just love Spellcheck that gets the words wrong all the time. Definitely always downshift, and do practice heel and toe as it will help you be proficient at the track. Coasting and using the brakes is an absolutely horrible habit to get into and it could get you into trouble if in a severe situation you try doing that instead of just what comes natural.
The following 3 users liked this post by WillyDaP:
damage98MO (08-26-2023), Frankie V. (08-25-2023), GoTime (08-27-2023)
Old 08-25-2023 | 12:25 PM
wdb's Avatar
wdb
Well, when something breaks, it needs to heal...
The following 6 users liked this post by wdb:
blacksquid (08-30-2023), damage98MO (08-26-2023), Frankie V. (08-25-2023), Gary12000 (08-25-2023), Mike Murphy (08-25-2023), WillyDaP (08-25-2023) and 1 others liked this post. (Show less...)
Semitone's Avatar
Semitone
Usually...I downshift for highway exits but not for red lights. Sometimes, on exits, I will skip down a couple gears, say go from 4 to 2. If it's smooth, which it usually is, I don't worry about it, if it's a bit of jerky, I think "Hmm...I might not get a 100K from this clutch."
I've owned manuals primarily for over 30 years. Never seemed to experience excessive wear for brakes or clutches. The only issue i ever had was getting my wife to break her habit of short shifting, She is primarily a manual driver but grew up with conserving fuel in mind. I finally got her to drive at higher RPMs in the torque band. We both are big fans of Italian tuneups, even on German cars, LOL.
Old 08-25-2023 | 12:30 PM
DBJoe996's Avatar
DBJoe996
What's a break? Huh...
Old 08-25-2023 | 12:35 PM
hatchetf15's Avatar
hatchetf15
Brakes are cheaper than transmissions.
The following 7 users liked this post by hatchetf15:
C4911 (08-27-2023), evoroadster (08-29-2023), Frankie V. (08-25-2023), GoTime (08-27-2023), Marv (08-26-2023), mjb2448 (08-26-2023), pdxmotorhead (08-27-2023) and 2 others liked this post. (Show less...)
Old 08-25-2023 | 01:18 PM
Gary12000's Avatar
Gary12000
Default Break
Thats wear u stap an hav a ress.
Old 08-25-2023 | 01:20 PM
brontosaurus's Avatar
brontosaurus
I am lazy and generally coast down until I need to clutch into neutral. I've gotten used to the heavier clutch in my car but it's still a bit of effort after a while.
Gary12000's Avatar
Gary12000
Lets be kind says I, i find spellcheck randomly will change the spelling of my words from than to then and other little gems, i'm convinced to make me look like a nincompoop.. and if i miss type this is a good cover story..
Old 08-25-2023 | 03:54 PM
relays's Avatar
relays
If you match revs as you downshift the added clutch wear is negligible. If you let the revs fall during downshifting and let the clutch "pull" the engine rpm higher as you engage it in the lower gear, you will cause more clutch wear. If you understand and visualize the relative speeds of the flywheel and clutch disc during the shifting process, you will understand why this is. Rev matching doesn't necessarily require you to be heel-toeing, although that is a good skill and worth practicing. Personally, I heel-town downshift almost always because it's fun, good practice and may give you a slightly improved reaction time if you need to accelerate suddenly to prevent an accident. Although when I had a manual car as my DD in heavy traffic, I was definitely lazier about it.
The following 2 users liked this post by relays:
Old 08-25-2023 | 04:08 PM
996-CAB's Avatar
996-CAB
If my car is moving, it is in the appropriate gear for the current speed.
The following 6 users liked this post by 996-CAB:
Boff (08-25-2023), cboxell (08-25-2023), damage98MO (08-26-2023), Frankie V. (08-25-2023), Mike Murphy (08-25-2023), zbomb (08-25-2023) and 1 others liked this post. (Show less...)
Old 08-25-2023 | 04:58 PM
Mike Murphy's Avatar
Mike Murphy
This is what my father taught me as well. It answers many, many questions.
To the OP, do whatever you want, either way. I just recommend rev matching to maintain a long clutch life.
The following 2 users liked this post by Mike Murphy:
Frankie V. (08-25-2023), wdb (08-25-2023)
Old 08-25-2023 | 06:45 PM
Frankie V.'s Avatar
Frankie V.
All great info thank you!
Quick Reply: Opinions on downshifting
