996 Forum 1999-2005
Need some advise on a 03 c4s, please!
Old 03-14-2023, 05:19 PM
HK G36C
HK G36C's Avatar
Default Need some advise on a 03 c4s, please!
I have had a 993, 991, but never a 996 C4S. I need advise to look out for issues that are common on these cars. My 993 has issues of its own which ended up costing a ton to fix. My 991 was trouble free! Thank you!
pulpo (03-14-2023)
Old 03-14-2023, 05:24 PM
brontosaurus
brontosaurus's Avatar
The best advice would just be to either buy a 1999 C2 or a 996.2 Turbo. C4S has all the weight and nothing you really want. For the money a nice C4S commands, I'd much rather end up in a slightly less nice Turbo and not have to deal with a $15k M96.0 time bomb and having two pointlessly driven front wheels.
HK G36C (03-15-2023)
Old 03-14-2023, 05:37 PM
pulpo
pulpo's Avatar
love my 996 C4S it is my favorite driving car I've ever owned, including other 911s.
Things to look out for are consistent with the other M96 engine cars, so you'll want to check that the IMS bearing has been replaced, or you should do so upon acquiring. The other bogeyman is bore scoring, which you can rule out by scoping the bottom of the cylinders from the sump. A warm weather car with regular oil changes is less likely to have scoring.
Other than that I cannot think of anything. Many of them will have little cosmetic things, like cracked taillights is incredibly common. Black foam coming through the hvac vents. And then there are the things going out with age, like the window regulators will likely be busted. Water pump and thermostat replacement seem to be a common preventative maintenance item, and many people upgrade the AOS to the UAOS. The problems are all well known and documented and most have an easy fix.
The following 5 users liked this post by pulpo:
dporto (03-16-2023), HK G36C (03-15-2023), imhighlander (03-15-2023), rrbarrios14 (03-24-2023), wdb (03-15-2023)
Old 03-15-2023, 12:32 AM
HK G36C
HK G36C's Avatar
Thank you! Is there any way to tell whether the IMS bearing has been replaced? Are there any signs to look for? Thank you! The car has been in the PNW for all of its life and maintained by the dealer.
Old 03-15-2023, 12:45 AM
pulpo
pulpo's Avatar
I believe you'd need the engine or trans out to 100% verify if the IMS has been changed. People usually do it when they replace the clutch. If there is no invoice/proof it it being done I'd assume it's original and should be done.
HK G36C (03-16-2023)
Old 03-15-2023, 12:52 AM
HK G36C
HK G36C's Avatar
What is the cost of getting the IMS changed?
Old 03-15-2023, 12:57 AM
pulpo
pulpo's Avatar
Usually $1500-$3000 depending on labor and if you do the clutch while you're in there.
Old 03-15-2023, 01:00 AM
HK G36C
HK G36C's Avatar
Thank you! I am getting a PPI and see what turns out, so I need to budget 3k! The car has 58k on her! I remember knowing how to test my clutch in my 993...that was many years ago!
Old 03-15-2023, 01:31 AM
allcool
allcool's Avatar
If you're lucky, might see an extra aftermarket oil line going to the imsb and you'll know...
Old 03-15-2023, 02:06 AM
GC996
GC996's Avatar
Received 3,798 Likes on 2,169 Posts
Since you will be in the area, consider testing your oil, drop the sump to see what's in there, check the oil filter, and scope the bores as well. If all checks out, next step is imsb, rms, check the clutch and flywheel.
If you are feeling your oats, might as well do the uaos, spark plugs, coils, fuel injectors and the water pump.
Then drive the hell out of it.
Old 03-15-2023, 09:35 AM
parris
parris's Avatar
Yeah, except for the fact that was the faster NA car of the 996 range (non GT cars) or that was considered by most of the specialized press from the era as "The best 996, second only to the GT3"...
To the OP. Make your due diligence before the buy, as with any used car: ask for maintenance records (the most well taken care, the better) and do a PPI if possible. If everything seems ok, go for it and assume that they are all 20+ years old cars and past reliability does not guarantee future reliability
shft22 (03-15-2023)
Old 03-15-2023, 09:50 AM
brontosaurus
IF you're referencing the ring time, that was only due to the upgraded tires that came on the C4S vs C2. All things equal the C2 wins every time. Adding 200lbs and more driven wheels when the car isn't traction limited by power only makes for a slower car.
Old 03-15-2023, 11:29 AM
wdb
wdb's Avatar
Received 1,216 Likes on 662 Posts
FYI to the OP: this is highly opinionated.
C4S 996's are highly sought after and good ones bring a price premium. That doesn't happen if they're bad cars.
c210rg (03-17-2023)
Old 03-15-2023, 11:32 AM
mtnroads
mtnroads's Avatar
Another point of view about the C4S awd. 1. It's the same suspension as the revered Turbo. 2. The added front weight helps balance the rear engine weight bias, yielding superb handling (especially on track). 3. TRACTION in all situations.
Old 03-15-2023, 11:36 AM
mtnroads
mtnroads's Avatar
I forgot to mention - 4. The best butt of all 996s!
The following 4 users liked this post by mtnroads:
c210rg (03-17-2023), HK G36C (03-16-2023), Ldino21 (03-20-2023), shft22 (03-15-2023)
Quick Reply: Need some advise on a 03 c4s, please!
