996 Forum 1999-2005
Tires: How old is too old for basic use?
Old Feb 1, 2023 | 12:11 AM
imhighlander's Avatar
imhighlander
Default Tires: How old is too old for basic use?
I'm aware of the conventional wisdom that tires more than 4-5 years should be replaced, but I'm hoping for a practical dialogue to better understand the reasons for this practice.
I have a set of 19" lobster forks shod in a set of Michelin Pilot Sports with 2006 date codes. The tires have excellent tread, but I'm sure the rubber is quite stiff.
I certainly wouldn't track them in an HPDE, but what about a trip to the autocross? Toodling around town? Highway speeds?
Is the risk a sudden catastrophic failure, or is it more about a greasy, hard rubber sensation, longer braking distance, and squirrelly handling? Combination of these? Something else?
I'm trying to understand the specific reasons to retire old rubber. I don't really plan to run these wheels until I get them refinished and new tires fitted anyway, but this forum is a deep well of knowledge, so I hope to learn something new.
Old Feb 1, 2023 | 12:39 AM
TexSquirrel's Avatar
TexSquirrel
I wouldn’t drive on tires older than 6 years old.
Same goes for my family.
I replace tires long before then normally.
Older tires affect braking and handling.
Old Feb 1, 2023 | 12:50 AM
pulpo's Avatar
pulpo
https://www.thedrive.com/article/518...rs-fatal-crash
I'm going to pick up a car tomorrow with tires from 2013. I'm not worried about driving it home but tires will be the first thing done. Autocross, no way.
Old Feb 1, 2023 | 02:17 AM
Ben8jam's Avatar
Ben8jam
I bought my "still" new to me 1999 back in November with full tread tires but from 2016. They are hard, rough, and feel like sliding around on plastic. I only have them on still as getting items sorted out - plus going to swap to new wheels shortly. But there's no reason to save a few bucks and drive unsafe tires.
Old Feb 1, 2023 | 04:20 AM
frederik's Avatar
frederik
Tires from 2006 are 17 years old, more than 10 years past any reasonable lifetime for a Porsche tire. Don't use them at all.
Old Feb 1, 2023 | 05:54 AM
TheChunkNorris's Avatar
TheChunkNorris
We’d swap out or tire inventory every year when I worked for Lexus back in the day and we couldn’t sell tires older than 3yrs old from vendors. I would probably consider them as a spare and limited highway use. Honestly the sidewalls will be more susceptible to damage due to put holes and alike. I don’t think tire separation would be an issue at low speeds but wouldn’t do much if any highway travel.
Old Feb 1, 2023 | 07:06 AM
RWPinNC's Avatar
RWPinNC
Tires harden as the rubber begins to lose the volatile gases that affect the tire's compound. This generally starts as soon as the protective coating is scrubbed off at first use. The rate of rubber hardening can be affected by the type of exposure. A tire with lots of miles on a car that sits outside, exposed to temps and sunlight, may easily be toast in 4 years, where a tire with lower use stored in a protected garage might logically have a longer safe life.
My 996 bought last year came with Pilot Sports with 2015 date codes, but were purchased and installed at a Michelin dealer in 2018, garage-stored, and have about 5000-6000 miles on them. They still stick like they should, and I consider them completely safe for road use, but will likely replace in 12-18 months.
It's also worth noting that the normal standard for HPDE events is a tire manufacture date of 4 years or less. Since this age standard applies to high speed events, clearly tires don't disintegrate at 4 1/2 years.
Just another perspective....
Old Feb 1, 2023 | 11:38 AM
GC996's Avatar
GC996
Certainly wouldn't canyon carve or track an old set of tires. But don't think for a minute you aren't at risk locally on the hwy or street with either less grip or rubber that is brittle.
good rubber + good brakes = good outcomes
Old Feb 1, 2023 | 12:16 PM
EVOMMM's Avatar
EVOMMM
Some manufacturers age quicker then others my Michelin always start dry rot much earlier then my continental on the same car
I tend to go max 7 years road use 3 on tracked
Old Feb 1, 2023 | 01:34 PM
Porschetech3's Avatar
Porschetech3
Tires over 6 years old are only good for "burn-outs" , " drifting", and " lots of smoke"....nothing else....the older the more dangerous..
Old Feb 1, 2023 | 06:20 PM
sanyata's Avatar
sanyata
From Michelin's web site:
"While most tires will need replacement before they achieve 10 years, it is recommended that any tires in service 10 years or more from the date of manufacture, including spare tires, be replaced with new tires as a simple precaution even if such tires appear serviceable and even if they have not reached the legal wear limit."
Old Feb 2, 2023 | 12:12 AM
pdxmotorhead's Avatar
pdxmotorhead
You can buy a Durometer gage from various racing parts and equipment sites, you can see how hard the tires are compared to new.
I've seen 2 year old tires that hard already dried out and were hard as a rock.
Old Feb 2, 2023 | 10:10 AM
sanyata's Avatar
sanyata
Interesting thread here:
Tire Date Code - Sale Date - Rennlist - Porsche Discussion Forums
Kind of like oil threads, many of them out there.
Old Feb 2, 2023 | 12:04 PM
sdematt's Avatar
sdematt
Veteran: Canadian Forces
I've got a set of 10 year old winters that my Turbo is currently sitting on in the garage, but my plan is to replace them this year.
I'm trying to replace at 6-8 years, but since I basically only do limited driving on all my cars, I'm okay keeping them on a teeny bit longer...if they look good and feel good and check out. Any cracks or anything - gone.
Old Feb 2, 2023 | 02:14 PM
theprf's Avatar
theprf
The tires on my Cayenne are about 12 years old. They are rather hard, somewhat out of balance, and take a set when cold. I plan to replace them.... eventually.
