Brake Pad Recommendations Needed
This is how I feel also. I am a huge sucker for brake pad bite. I like pads to practically throw me through the window when I use them. Brake dust stinks, but this is not a daily driver for me so I just have to keep the car clean after use. Ceramic coating the car and the wheels goes a long way. Allows you to spray the car off every so often and keep debris off the surfaces.
Ceramic coatings, especially for wheels are often misunderstood. Brake dust will still form on wheels and a simple spray down, even with a power washer, will remove a lot of the the brake dust but it will not leave your wheels clean. You still need to use an appropriate cleaner and a brush. What the ceramic coating will do for you is make the cleaning process significantly easier as the dust won't "bake" into the rim. Cleaning requires very little effort. One of the best products for wheels and tires is P&S Brake Buster. I buy it by a gallon and dilute it. Not only does it clean really well but it includes rust inhibitors.
GC996 (01-20-2023)
Pete,
Agreed, brake feel at the end of the day is a game breaker for everyone.
Thanks for the P&S recomendation. What do you recomend for a ceramic wheel coating?
The following 2 users liked this post by plpete84:
damage98MO (02-24-2023),
GC996 (01-20-2023)
I use Akebono and feel like they are pretty good, good bite, and low dust.
Thanks to all for your reply’s. I have no issues with performance of the brake pads currently on the car. With that in mind, I’m going to take the initial step to ceramic coat the wheels and see where that takes me. Take from there after a few months.
Nein, love to hear how it goes. Anything to make it easy to clean the wheels is a win. Maybe some of the guys with the detailing knowledge will start a thread on various topics.
Best product I ever used for cleaning wheels:
GYEON Quartz Q²M Iron 500 ml - Iron Remover Breaks Down Embedded Iron Deposits in Paint and Wheels https://a.co/d/0k9p7zP
if you go with Hawk ceramic yellow pads, you will hardly use it. These pads are almost 0 dust.
Hawk Performance HB550Z.634 Performance Ceramic Brake Pad https://a.co/d/3hi225z
Hawk Performance HB290Z.583 Performance Ceramic Brake Pad https://a.co/d/hBsVjBq
GC996 - Definitely will report back on how it goes. I ordered the ceramic coating today. It will take a little time (prep/drive time) to get a good feel for how it works.
GC996 (01-21-2023)
It’s been about 3 weeks since I’ve applied ceramic coating to 3 of 4 wheels (two layers). I left one untreated to determine if there’s any significant difference in brake dust build up. I’ve put around 200 miles on the car in that 3 week period. Normally there’s a significant film of brake dust on the wheels within a 50 mile distance making them have a dingy (sp?) dark grey/black look. I can confirm that there’s only a slight film of brake dust after 200 miles on the three, but more importantly, a quick spray of the water hose wipes it all away. Prior, the brake dust clung to the wheels requiring more of a mechanical (scrubbing) action taking significant time (based on the wheel type I have). Overall, I’m happy with the results and recommend doing this if you haven’t already. Not sure how long the coating will last.
The following 5 users liked this post by Nein96:
EVOMMM (02-23-2023),
googone20 (02-23-2023),
jandackson (02-23-2023),
Mike Murphy (02-23-2023),
plpete84 (02-24-2023)
Very good to hear. Can't imagine life without Pagid yellows. Good to know there is an dust solution.
