996 Forum 1999-2005
Bore scoring
Old Sep 28, 2022 | 12:41 PM
hkovalcik's Avatar
hkovalcik
Will post the entire thread -
http://www.911uk.com/viewtopic.php?p=1389088
Old Sep 28, 2022 | 12:43 PM
yelcab's Avatar
yelcab
deleted
Old Sep 28, 2022 | 01:18 PM
Porschetech3's Avatar
Porschetech3
What a long winded bunch of BS... Imagine trying to tell a customer who just paid $80k for a new 996 that his noise couldn't be cured, just to live with it...lol
Also not only is the 3.4 piston pin off-set, but the I know for sure and it documented here that 3.6 996 has the same piston pin off-set..
and don't kid yourself that IMSB failure is not an issue, lol, or borescoring either...hell IMSB even has it's own Facebook page with huge following...lol
Old Sep 28, 2022 | 01:22 PM
wildbilly32's Avatar
wildbilly32
What year/model? What symptoms did you have aside from scoping it and seeing scoring?
2005(996)/C4S. Classic symptoms that all started minimal and progressed over five years(2014-2019) to severe especially the ticking.
Occasional puff of smoke on start up, sooty left side tailpipe(I thought what the heck it's a tailpipe after all), Some spitting on garage floor after first start of the day(I figured moisture/carbon from humidity), slow increase in oil consumption, faint ticking from bank two side that became pronounced by year five. The pic is my cylinder six. Cylinder five was just behind it in severity. Cylinder four was starting the same.
My guess is previous owners followed the owners manual on oil changes as GC996 suggests above.
Scoring is NOT hype...
Old Sep 28, 2022 | 01:37 PM
plpete84's Avatar
plpete84
Assuming that was 5 years under your ownership? When you noticed the symptoms did you do anything different?
Old Sep 28, 2022 | 02:03 PM
gbarron's Avatar
gbarron
If I'm not mistaken, that article was written by Baz of Hartech fame. They are a well known UK Porsche engine specialist: https://www.hartech.org/ I am not here to argue his reasoning is legit or BS, but knowing their history I would expect his knowledge base to be high. It's possible his post is being taken out of context and erroneously applied to a different issue. Baz is well versed in bore scoring & IMSB issues, they rebuild engines daily for these types of failures. His thoughts are likely directed at ticking complaints where bore scoring has already been eliminated as the cause.
Old Sep 28, 2022 | 02:09 PM
Dr_Strangelove's Avatar
Dr_Strangelove
This forum actually has a decent amount of "Feel Good" threads now and then, however, the forum is not where most people come to wax poetic. If you're "reading a lot of problems" it's probably a symptom of reading the trouble forums. If you gathered your data by attending PCA meets and talking to current owners you'd probably already own one by now.
Old Sep 28, 2022 | 02:52 PM
Porschetech3
The fact of the matter is that the 996 M96 doesn't have "unusual noises" that cannot be cured...
I know who Baz is and just got tired of reading.....and this comment I found at the top set the stage..".If it has a tick after a rebuild it is almost certainly nothing to be concerned about "
Yes right...lol
7 Porsche Models That Have Aged Like Fine Wine
Old Sep 28, 2022 | 02:54 PM
hkovalcik's Avatar
hkovalcik
I’m not asking what the signs are. I’m asking what other symptoms (edit- signs) he had.
so now we’re using social media as credibility.
I don’t know what I’m talking about, but I’m convinced 95% of you don’t either.
Old Sep 28, 2022 | 02:57 PM
hkovalcik's Avatar
hkovalcik
I’ve said many times that a tick at idle with no other symptoms is probably not bore scoring, and something else. That’s why I asked what else that guy was experiencing.
Old Sep 28, 2022 | 03:00 PM
GC996's Avatar
GC996
I’m not asking what the signs are. I’m asking what other symptoms he had.
Not certain the difference between symptoms or signs, but the only way to truly know to confirm the signs or symptoms is to scope it.
Old Sep 28, 2022 | 03:01 PM
hkovalcik's Avatar
hkovalcik
GC, you know that I know this.
signs / symptoms - meant to say signs again.
Old Sep 28, 2022 | 03:28 PM
GC996's Avatar
GC996
You know the routine, when you are a newbie, you should trust nothing and verify. Because you dont know if the info you are getting is good or bad.
When you have been around the block for 20 years, you already know the issues, what solutions actually make sense, and which ones work.
The challenge is the newbies will question as they should and the seasoned vets will keep giving the same answers. Eventually the newbies get enough information to verify and enough knowledge and experience to apply the info properly.
But to your point, sure, there are alot of folks that really have no idea.
Old Sep 28, 2022 | 03:54 PM
wildbilly32
#1: Yes
#2: No. I was in a continual state of denial.
Old Sep 28, 2022 | 04:07 PM
plpete84's Avatar
plpete84
#1: Yes
Cool - so it seems like it took more or less 5 years, without doing anything different than previous owners, to get to the state you found yourself in where a rebuild was the only way to go. The reason I asked, for all those that have posted photos with fear of bore scoring (even though they're streaks at best) and thinking they need an immediate rebuild, it would appear that as long as you adjust your behavior now, you easily could have more than 5 years of driving you could potentially do while you figure out future steps and save up some coin. By adjusting your behavior I mean proper oil changes / interval and a low temp thermostat at the very least. From there just track metals with a UOA. You can't undo what's been done but you can certainly manage it for quite some time. Often what's been done isn't as bad as the internet may have you believe. Fear has big eyes.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
