View Poll Results: What has been your experience with the "orange cap" intake mod?
Never tried it
23
42.59%
Tried it, but later removed it
5
9.26%
Still using it, but might remove it in the future
7
12.96%
Still using it and never going back
19
35.19%
Voters: 54. You may not vote on this poll
996 Intake "Orange Cap" / Resonator Delete Poll
After so much discussion about the "Orange Cap" mod on RL (mostly long ago), and after all this time, I thought it would be good to do a poll to find whether in the long term people kept or abandoned this simple mod. Please share your experiences with this mod by voting in the poll and posting your experiences with it.
peterp (08-26-2022)
Did today
Did the mod over 10 years ago. Yes, I would do it again. Sounds great.
Here is a picture. Engine bay is a little dirty thanks to dust from road construction.
Schu3507 (08-26-2022)
Mine is capped. Ran the car back to back with and without and honestly it sounds almost the same. This was after installing BB mufflers so not sure if that's a variable factor. Still leave it capped because why not.
The following 2 users liked this post by Billup:
Mike Murphy (08-27-2022),
I wonder if the high flow air filter helps and the silicone inlet?
Fwiw, over the years I went from bmc to kn to the oem filter. I didnt notice a difference in sound at any rpm. Didn't notice any difference in performance in the butt dyno either. But as we all know, the butt dyno may not be accurate.
Right know I am using the oem filter. just easier.
FunWithPaul (07-04-2024)
GC996 (08-26-2022)
I have a feeling most have gone with the silicone pipe approach. I actually swapped back to stock for a bit as the aftermarket supplied cap somehow blew off. I found a better cap and went back to the silicone pipe and cap. I like it. Can hear more induction noise and its probably psychological but the car feels a touch more responsive. I wouldn't go back to stock. Next thing I would do is couple with with a 997 3.8 airbox.
The following 5 users liked this post by SoCal911t:
Gary12000 (08-29-2022),
GC996 (08-27-2022),
imhighlander (06-22-2024),
peterp (08-27-2022),
wdb (08-26-2022)
This looks like a good solution. Are you using the 1 1/2" size in your photo and does expand enough to plug it? I ask because the similar ones I see on Amazon (e.g.
) look like they only expand to 1 5/8" (I think some of the plugs are closer to 1.75"). Mine would be going on a stock 996.1 airbox, not the 3.8.
My car came with the silicone pipe and cap when I bought it, so I can’t comment on the effect on sound. But all I know is, along with the Fister mod the car also came with, it sounds just like the race cars (albeit much less loud) at high rpm. Intoxicating!
Originally Posted by Billup;[url=tel:18326863
18326863[/url]]Mine is capped. Ran the car back to back with and without and honestly it sounds almost the same. This was after installing BB mufflers so not sure if that's a variable factor. Still leave it capped because why not.
There’s a Boxster mod for this intake as well, and it really sounds great, as the engine is even closer to your ears.
There’s even an air box mod on the 84-89 3.2 Carrera where you drill a couple of holes in the air box for a better sound.
Most stock 911s are pretty quiet from the factory (unless they have PSE), but that flat-6 is glorious and needs to be unleashed a bit.
Does it count if you have an IPD plenum and a GT3 throttle body (and a black cap, and a FSI 3.8l stage II )
