AC Recharge
AC Recharge
Noticed my AC was cool but not cold. Scheduled an appointment to have a recharge of the system. The AC system has not been touched in 24 years. Factory fill. Vacuum on system showed no leaks, so removed 0.74 pounds from the system and recharged 1.97 pounds R134a with oil. Damn it blows cold now, so much so I have to set the temp on the HVAC in the upper 70's even on a 90 degree + day. If you haven't had this done like me, something to consider.
All in at an indie $133, mostly cost of freon. One of the cheapest and best repairs on my 996 ever. Nice to have the cool air and defrost working perfectly.
The following 3 users liked this post by DBJoe996:
What did they charge for the Freon?
That’s less than 2 cans. (Normally runs $10 each or less)
it’s even cheaper when purchased in bulk tank.
Mine is somewhat tepid and seems to take quite awhile to cool down at all. I checked charge level and it was fine. Next I will remove front bumper cover and clean radiators etc. If still only somewhat cold I will follow your lead.
The invoice does not specify cost of the freon. I just paid and moved on. Seemed very fair to me. Took about an hour, 20 minutes on the vacuum hold test. Look, an AC system recharge is not something someone can DIY. It is really not best to dump a can from the auto parts store in the system because you don't know what you are getting. It requires a pretty specialized machine to do an extract, flush with nitrogen and refill. Just my two cents....
The following 2 users liked this post by DBJoe996:
dporto (07-02-2022),
sasilverbullet (07-02-2022)
Butt I hear you,. It's your car, and you're certainly not wrong to care for it.
I’ve got to get mine checked. I had it done about 5 years ago but it’s not even getting cool now. I’ve got to have full vac check done first, then a refill if ok…I think last time it cost me about $225… been dreading bringing it in…
damage98MO (07-02-2022)
My cost on 134A has gone up 400% over the last year, 30pound cyl is now close to $400.00.We charge 1HR Labor $135.00 plus Freon at $25.00 per pound.
A 24 yr old car, even with no "leaks", can have some seepage. The seals around the compressor shaft are not perfect.
If you have it checked and in 2-3 years you're having an appreciable loss, then yes, you have a "leak".
islaTurbine (07-04-2022)
I guess when I fill my other empty tank I‘ll see how much R134A has gone up.
I don’t charge labor.
Try R12.
If you can find it. Tell us how much for R12 now. I used to sell that stuff. Zerex owned by Valvoline bought all the R12 supply in the US. Every year we would raise the price. At one point in time I had control with prices so I would set a price for Mexico and then another price for the rest of Latin America. I’m just curious now how expensive that stuff is. I used to buy cans for 99 cents, way back when.
