Lowered 996s
imhighlander (10-13-2022)
#62
It is a direct lift.
igrip (06-29-2024)
#65
Looks great! was thinking of going to 295/35 instead of 295/30 as well. Looks tight, did you have any clearance issues?
#67
Well I can finally contribute to this thread...
H&R/Bilstein B8s/15mm spacer all around. Absolutely loving the setup. Ride and handling are better than stock. It's sharper and handles flatter yet somehow is more compliant..magic.
#69
Mine recently with 245/645, 305/680 18’s.
zbomb (10-12-2022)
#70
NYC has some atrocious roads so proper ride quality was a requisite
You were 100% right. This setup is pretty much all I could need. Will probably add some sways in the future. Love those OZ wheels by the way
#71
I think you'll be happy with that set up. I have H&R springs with Bilstein B8's and RSS adjustable toe arms and love the way it handles and rides.
On 19" BBS LM. Not currently on the car and I may sell them soon.
On factory '02 5 spokes (current set up)
#73
Here's my 2003 C4S on H&R springs and Bilstein shocks. I'm running factory 18" twists with 10mm spacers on the front and 15mm (I think) on the back to get as flush as I can. I run @Rennline extended studs, which I 100% recommend not just for spacers, but to make wheel mounting easier. I'm running 285s on the back because I was afraid of fender rub, but I think I could go with 295s and still be fine.
I've been focused on mechanical restoration this year, and plan some cosmetics in 2023. (Paint correction; painting wheels "white gold" or similar; side script; tartan interior inserts...)
