996 Forum 1999-2005
Anyone know what these numbers mean stamped on the block?
Old 01-03-2022 | 10:30 PM
Kris Murphy's Avatar
Kris Murphy
Default Anyone know what these numbers mean stamped on the block?
I was pulling a motor (that I know has an LN Bearing) and noticed numbers stamped in the block behind the sump (see pic).
Anyone know what these are there?
Guessing the motor had extensive work at some point. It is not an AT engine.
Old 01-04-2022 | 12:49 AM
hatchetf15's Avatar
hatchetf15
Matching case halves?
Old 01-04-2022 | 02:03 AM
Porschetech3's Avatar
Porschetech3
Correct !!!
There is a pair on the head and head cover also....
dporto (01-05-2022)
Old 01-04-2022 | 09:23 AM
Kris Murphy
Originally Posted by Porschetech3
Correct !!!
Was this done at the factory? I have seen many of these engines and this is the first time I've ever seen something stamped there. For a while when I was much dumber, I used to use that spot as a jack point...
Old 01-04-2022 | 11:04 AM
Charles Navarro's Avatar
Charles Navarro
Yes, these markings are from the factory.
Old 01-04-2022 | 11:38 AM
Kris Murphy
Interesting, never seen them before in any other 996 engine that I have worked on. This is the first 2001 that I have worked on, maybe it started at that point, although the AT engine with the big 997 bearing that is in my car now (made well after 2001) doesn't have them.
Old 01-04-2022 | 11:45 AM
Charles Navarro
That's actually one of our checks we do when we get blocks in for sleeving. If the numbers don't match, the first thing we do is call the customer.
Old 01-04-2022 | 02:03 PM
Porschetech3
Most of the time it takes some forensic cleaning to be able to see and read the numbers, it doesn't take much dirt and grime to hide them, but I have never seen any castings without them...
Old 01-04-2022 | 02:11 PM
Kris Murphy
Time for me to get cleaning the other cars. It's amazing with how covered in oil and grime this engine is they are so visible.
Old 01-04-2022 | 02:42 PM
Porschetech3
Yea, a dry corrosion is what will hide the numbers the most, you will think they are not there, then start cleaning and lightly sanding and they will appear like magic...lol
Old 01-04-2022 | 03:38 PM
wildbilly32's Avatar
wildbilly32
I bet those are not a comfortable phone calls as the price goes up exponentially from there!😳
Quick Reply: Anyone know what these numbers mean stamped on the block?
