996 Forum 1999-2005
ABS Harness Rubber Mounts
Old 07-25-2021 | 12:20 AM
gbarron's Avatar
gbarron
Default ABS Harness Rubber Mounts
Has anyone found a good alternative or replacement to mount the ABS harness in the metal holders after the factory rubber mounts disintegrate? My harnesses are fine, but the two mounts on each harness have given up the ghost. You can see the 2 mounts that slide over the harness in the attached picture. Thanks!
Old 07-25-2021 | 02:11 AM
De Jeeper's Avatar
De Jeeper
Creative zip ties or replace the harness.
Old 08-12-2021 | 08:32 PM
gbarron's Avatar
gbarron
I solved the problem...some correct sized grommets cut to go around the harness then pushed into the bracket for a tight fit!
SleepyCyclist (08-12-2021)
Old 08-12-2021 | 09:08 PM
SleepyCyclist's Avatar
SleepyCyclist
what size grommets?
Old 08-13-2021 | 01:25 AM
gbarron's Avatar
gbarron
Originally Posted by ManM
what size grommets?
I ordered 2 sizes as the brackets have different size openings: GR3076A (.8750 OD) and GR3065A (.8125 OD).
SleepyCyclist (08-13-2021)
Old 01-03-2022 | 02:54 PM
SleepyCyclist
Thanks gbarron for the tip!
bought a kit on Amazon
Amazon Amazon
5/8" grommet worked well.
Old 01-04-2022 | 01:31 PM
gbarron's Avatar
gbarron
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Glad you found some that worked, my only suggestion would be to rotate the grommet so the "cut" is positioned in the bracket 180 degrees from what your picture shows. Positioning it this way will better support the grommet and harness as the suspension moves.
Old 01-04-2022 | 03:59 PM
SleepyCyclist
good point. will do. thx.
Quick Reply: ABS Harness Rubber Mounts
