PCCM Plus A/C Blows Warm When Powered On
I brought it back to CAI and they checked the connection to the climate control unit...all solidly set. It was late so I took the car home and thought I'd reach out to the community for thoughts. What's the most likely issue....defective MOST control unit included with PCCM Plus? CAN Bus issue? I think I read somewhere that the Comfort CAN controller in 996 is incorporated in the instrument cluster and communicates between the cluster, radio and air conditioning. They did remove the instrument pod to gain access to route the microphone cable....could something have happened? This is so odd....hoping it's something simple.
I appreciate any thoughts.
Kevin
This is the problem with the A/C in my car. PCCM plus controls the brightness of the A/C control panel screen. When the PCCM plus display goes dim, the A/C control panel display goes dim together at the same amount (or brighter). It is the same for automatic brightness and the manual brightness. (With the OEM radio, it is synced with the three digital displays in the instrument cluster.)
The brightness in the day time with either automatic or manual is OK. The brightness in the night time is not dim enough with automatic. It is marginally better with manual. With the OEM radio, the brightness of both screens works very good (bright enough and dim enough) in all conditions, day, night, manual, and automatic.
Most of the time, the radio was not used and not turned on when I had the OEM radio. In the night time, the brightness of the A/C control panel became dim enough when the headlight was turned on (along with the three digital displays in the instrument cluster). So, my thinking was that with PCCM plus turned off and the headlight turned on, the A/C control panel display should go as dim as the OEM radio. It is not the case at all. In fact, the brightness goes to the brightest and gets stuck there. The brightness of the A/C control display works (marginally in a different way) only when PCCM plus is turned on.
Luckily, the A/C (temperature control) works in my car. But, there are other problems. When the scan was made with PIWIS for any fault, the A/C unit and the instrument cluster were not communicating properly. I don’t know if it was coincident.
Having said that, the onboard computer gets reset randomly. For example, the trip distance counter becomes “zero” randomly. The onboard computer is useless now.
May I continue? There are few more. The GPS and RBDS clock sync do not work. The navigation information is randomly displayed on the onboard computer without any active route in PCCM plus. The unit itself reboots randomly. I am not sure if this is a problem, but PCCM plus cannot be turned off independently. It means that PCCM plus always turns on automatically when the ignition is turned on. The OEM radio dose not do it.
I believe all of the problems (other than rebooting) are related to the installation with MOST. The OEM radio is integrated into the car. It looks like PCCM plus is trying but not exactly being integrated properly. I have been dealing with the problems since last fall. There are no solutions from the dealer or Porsche Cars North America so far.
Do you have any other problems, other than the A/C?
*****EDIT*****
I went back to the OEM radio once to see what happened. All of the problems went away. After PCCM plus was installed again, all of the problems came back with it.
Mine is 2004.
When I checked brightness setting in instrument panel is was set to brightest setting. As note above, no change in A/C control panel whether or not I turned lights on/off.
Yes. PCM 2.0 was re-installed to check if all of those problems were only associated with PCCM plus, and it was the case. Before switching back from PCM 2.0 to PCCM plus (hoping to get those problems repaired), the scan was made. The faults for the instrument cluster and the A/C unit only have come up after the installation of PCCM plus.
I only can guess because the dealers (more than one) and Porsche Cars North America do not have any information. My best guess from the information gathered so far is that PCCM plus is not integrated into the car properly for the installation with MOST. The configurations for CAN and the instrument clusters probably need to be changed to accommodate PCCM plus. The software/firmware of PCCM plus probably needs to be updated to accommodate MOST.
With analog installation, there should not be any problems once the installation is complete successfully (maybe with the exception of the one with navigation without MOST originally). In such case, PCCM plus is less integrated to the car.
I think CAI has more information and better insight about MOST. I am curious to know what they think.
The issues I have are as follows: A/C blows warm when powered on and operates correctly when off. The PCCM buttons don’t light up when headlights are on. Light sensor on PCCM doesn’t function. The rest of the unit functions as expected.
I have no way of knowing for sure but I wonder if issues with MOST installations have to do with the PCCM included MOST Control Unit?
I’m very disappointed that this Porsche approved product is proving to be a $1300+ headache for so many.
Please keep us posted on what you find out and I'll do the same. Thx. Kevin
1. A/C compressor would trip when PCCM Plus was powered on
2. Radio buttons would not illuminate
3. Radio would not power on / off with key
#1 was addressed when they realized the yellow square plug that was plugged into CDR23 (and had a spot to plug in on PCCM Plus) needed to be left disconnected. From what I was told, the yellow plug is an analog 12 volt turn on for the earlier cars, 97-02, both Bose and HiFi (black with red wire on the car side), data on the MOST cars 03-05, and analog low level signal (4 conductors) and ground for the 97-02 cars with HiFi package. In case of Bose, it takes high level/speaker level signal in from a separate brown speaker wire plug in radio cavity. The theory that the awesome guys at CAI think is the PCCM Plus doesn't know which car it's in, and may be throwing 12 volts into a data wire on the MOST Bus cars. The Porsche Technical Bulletin (which I gave to the guys) should likely say to not plug in the yellow square amp plug on the MOST bus cars! Once they unplugged the yellow plug the A/C compressor stopped kicking off when it was powered up. Fred - I'm thinking you need to have your installers make sure the yellow square plug is removed from the PCCM Plus.
#2 & 3 Resolved with tapping into switched accessory / illumination power. Now the radio powers up / down with key (can manually turn off as well) and the radio lights are illuminated when headlights are switched on.
I can't say enough how appreciative I am of Rod & Jake in troubleshooting and resolving my issues. I hope this post is of value to others in the future who may have similar problems.
My solution is a little easier: make sure the setting in the "hidden menu" of the PCCM+ unit is set to "CAN" and not to "AMP". This solved all issues for me - A/C is working fine, PCCM buttons are illuminated and it switches on/off with the key
My car is a 2003 Turbo with MOST and cd changer (originally had a CDR-23 as well)
