First time bore scope test
So as I look for my own 996, I decided to help a friend of mine change the oil on his 2003 C4S with about 76k miles.The car has been well maintained and purchased from a decent indy Porsche shop / dealer. Had all the usual suspects done, like IMS, RMS, AOS. I thought it would be a great opportunity to cut apart the filter and inspect cylinder #6 as I just got one of the Amazon bore scopes few members referenced I thought it would also be a great opportunity to at least pull out the #6 plug and take a look. After driving the car for about 1700 miles, I only noticed 2 lines of oil burn on the electronic gauge so nothing out of the ordinary. The oil looked good as well and it was changed right at about 5000 miles. He wanted to use Mobile1 so we went with that a new filter + plug washer. Upon cutting the filter open it was very clean. A few tiny plasticky specs but nothing that had us worried. Didn't see metal flakes at all.
Since cylinder 6 is the most accessible we pulled that plug. There was a little bit of oil on the metal gasket which we cleaned out. The plug was not fouled at all. Here is a not too great video of what we saw:
Yes, I'm very aware that this is not the ideal way to perform the test but we didn't have the time to drop the oil sump. It looks like there might be some early scoring happening. The interesting part is the thicker black score/scratch that you can see. There is no noticeable soot on the exhaust and no ticking either.
Thoughts? I think drive it and perscribe to Jake's 6 minute rule. The car does see some track time occasionally FWIW.
A) Do we continue to drive and potentially switch do a different oil? Perhaps add something like Ceratec that some have used to slow down the process? Obviously it's not a fix but it may slow down the progression?
B) Stop driving now and plan a rebuild
C) Keep driving and worry about it later
As motoo344 jokingly mentioned, it almost seems like we can all assume most people either have scoring or just haven't checked yet because no symptoms are showing, as in this case. Especially if you're in a climate that sees cold. Seems like warmer climates don't deal with this issue but there is no way of proving that. If that's the case, engine building sounds like a pretty good gig these days, if you know what you're doing!
i think getting a UOA is a smart move, especially if you plan on continued driving. At least you will be able to tell if metals continue to show up at higher levels as the car gets driven more. As for moving away from Mobil1 i will defer to more knowledgeable forum members, but i suspect the answer is yes. Good luck
Thanks Optionman1 - that's a great point. I'm wondering if the oil change interval should be increased to say every 3k miles to have a better sample rate than every 5k miles. Would love to hear about oil too. DT40 seems to be a popular choice but would it still apply at this point?
