Turbo Engine In A C2
Just for fun.... what would the most challenging parts of installing a Mezger engine and necessary parts (cooling, etc.) in a NA 996 C2?
There's been a couple of threads on this already, the big challenge is the DME and other electronic management systems that require a metric f*%k-ton of work...
The mechanicals would be fairly straightforward. You'd have to find a home for the intercoolers since they live in the widebody fenders. The real work is the electronics. You'd want to either go to a standalone engine management, or do a full harness/ECU swap.
Add a wing tail like the Old 930 ??
Open up ducts in the fenders and run them into the engine bay to help feed it.
Just buy a turbo casue its a whole metric crap-ton easier? and likely cheaper.
Anything is possible with enough time and money. You should see some of the cars that people shoehorn the turbo into... I was at Rennline earlier this year, and one of their projects was putting a 996TT engine into an early 70's chassis.
Free time and money...
I could be wrong, but I'm pretty sure the Bisimoto car uses a modified m96 engine.
Porschetech3 (11-26-2019)
