Build Thread: '99 C2 996 LS1 Swap
#31
I've thought about it as my plan C if I end up needting to do something..
I'd be going for a GM, LGW V6,, Probably the turbo out of a CT6,
smaller dimensions than the LS,, weight should be close to the 996(ish)
with another 60+ HP.. Pre-retune
2016–2019Cadillac CT6 404 hp (301 kW; 410 PS) @ 5700 RPM400 lb⋅ft (542 N⋅m) @ 2500-5100 RPMdyno chart
#32
I think a Cayman with an LS swap would make a great track toy!
#33
Will this be a track only car? I was messing around with a dry sump tank in my swapped 996 and the only logical place to put it would be the front trunk. Thats roughly 30+ feet of -16/-20 line or bended hard line. You give any thought where you would mount the tank?
#34
There are some tanks that are thin and tall, if you havent seen them, like about 6" in diameter and 2 1/2 feet tall..
They fit Midget race cars..
OR
Isn't there a gt/turbo exhaust that doesn't climb up in to the fenders, if you could clear the right muffler area a stock
early model tank would fit there.. Cool-Yet retro.
OR
#36
Reason is you could leverage on the LS platform for conversion kits.
(LV3 is a 6 cylinder LS engine, so an LS engine but shorter.
Would the LFX fit? It seems very tall? (Also different bellhousing than LS)
Edit:
Someone has measured the LFX, https://oppositelock.kinja.com/engin...ons-1760110530
LS measurements, https://ls1tech.com/forums/conversio...imensions.html
george_west (11-01-2019)
#37
The LV3 4.3 v6 would be interesting, however it's only rated at 300hp and I can't find any resource about pumping up the power. Did you ever consider this engine?
I stuffed 28” under my rear hood. Not sure how tall the LS is but going a non porsche v6 gives sooo much room in the engine bay.
From bottom of oil pan to top of supercharger.. 28”
RABjr (10-23-2021)
#38
The LV3 4.3 v6 would be interesting since it's so small and light, however it's only rated at 300hp and I can't find any resource about pumping up the power. Did you ever consider this engine?
Edit:
Edit:
I have looked at the 4.3 for my jeep, a FI setup on it would make it quite a good driving rig..
#39
Surprised the aftermarket hasnt responded more, seems like a perfect fit where LS is too much.
#40
It wouldn't be too hard to do a sheet metal intake for it.. Wonder if you could cut down a V8 one?
Not many folks playing with them.. Yet..
#41
E85:
So about the same top power as a 3.4 but with more torque and broader power band (a 3.4 seems to have about 255whp). Curious what would happen if the revlimiter was lifted 500-1000 RPM, torque would probably skydive but would make it easier to stay in the meat. Would the LS engine break from this? Or how do you make an LS survive 6500 rpm?
Reason for the engine would be that I think you could get away without cutting the frame? (It's also lighter making it way lighter than M96)
There are plenty of camshafts for the 5.3 V8s (https://gwatneyperformance.com/produ...#configuration)
Maybe regrind the V6 camshaft to these specs?
Reason for doing all this would be not to cut into your frame and if you don't have the need for >400hp and torque like an oil tanker.
Another "cheap" option would be the modern Escalade 6.2L engine with car intake.
#42
Here is some dynos (93 gas):
E85:
E85:
Reground cam would be a great place to start, but you're in uncharted territory. LT1 spec? The lv3 has torque to spare.
Also, I think the lv3 intake is considerably taller than a lsx variant. Measurements would be needed to confirm fitment.
#43
I've seen no aftermarket for these motors. I've been watching for a while and thought there would be something by now. Not cutting the crossmember is a big plus. Pushing the weight forward is nice too.
I found specs on the height of the engine from GM, it's a few inches taller than the car engines due to the manifold.
It seems like having some extra clearance would make this swap much easier. Note that I haven't done a M96->LS swap so I don't know where it would benefit, but it seems like a shorter engine would be a plus.
LV3:
The V8 version:
LS1 (different source)
Seems like car engines are ~27" tall and truck engines are ~30 tall. The v6 is ~3 inch shorter.
The LS1 dimensions are from a different source so the measuring method might differ.
#44
Good information .Having done the ls swap :. The 3 inch height increase is a show stopper .In order to clear the suspension crossmember the ls6 has less than a inch clearance between the intake manifold and the body ..One could make a new suspension cross member but ground clearance would be really bad .So the challenge is a shorter intake solution-if one wanted to really do it right probably look at individual throttle bodies .The shorter length is a plus -no body cutting -stock trunk latch and could probably do a intake box similar to the m96 .
#45
I didn't realize this would spark such a lengthy discussion!
FWIW, My LS1 with the F body pan is 25" from bottom of pan to top of intake. Shorter pans are available such as the "batwing" early Corvette pan shown at approximately 22" for the same measurement. Hence why I am finding the shallowest pan possible to run my exhaust underneath. I can run a shallow dry sump pan or a wet sump "front" sump pan which would be physically to the rear of the car. I am leaning towards this option but haven't fully abandoned the dry sump setup. I may just do a dry sump later after I see issues with the wet sump. Plenty of space to mount everything but it would take time and be more initial investment than I wanted. I have other plans following this build so I don't want to spend too much of either right in the middle of it. I am focusing on exhaust and initial clean setup.
I found an original Corvette ac compressor mount for my small F body compressor. Hoping I don't have to change the clutch and it aligns correctly. ICT low alternator mount worked well. Still pushing forward with the build, just nothing good enough to take pictures for. I will probably have a real update in two weeks or so. I want to have the car running or at least cranking around New Years. I'll probably cut the rear crossmember out next weekend, mount the LS1, and start plumbing.
This is a daily driver build that will see occasional but sometimes vigorous track time and my needs or the plan may change as I see fit. Buckle up if you wanted something concrete
