First issue. A while back I changed out my front struts and also the drop links. Easy DIY. No issues after this and the car drove fine and braked fine. However, I just replaced my rotors and pads and now if I'm going around 20 mph and if I hit the brakes the car stops fine and straight if the steering wheel is straight. But at this speed if the steering wheel is slightly to the left when I brake the car tracks left as I come to a stop. And if the steering wheel is slightly to the right when I brake the car tracks right as I come to a stop. Never noticed this before the brake/rotor job. Normal, not normal, something I did wrong? At speeds higher than 20 mph the cars tracks straight regardless of steering position not being perfectly straight.
Second issue. I replaced my water pump recently, that went well, quite easy in fact. To do this I lifted the engine and removed those bolts to pull the engine carrier out a bit to access the pump. Now I notice my left tail pipe is dropped down a bit. Before it was not and I know this because I swapped out my engine mounts and both pipes were even and nice and tight up to the body. I'm thinking I may have tightened the bolts back up when I still had the engine lifted with my floor jack. Maybe the bolts should have been tightened with the engine hanging freely. Would this cause the dropped right tail pipe? Thinking I should loosen them back up and then re-tighten them with the car sitting normal and see if this helps. Or maybe the other way around, maybe tighten them with the engine lifted. I'm also thinking that maybe I had the engine lifted unevenly and then tightened them with the engine slightly tilted and that could be the reason for the tail pipe drop on the right side.
You're not supposed to raise the engine with a jack, rather you support it from dropping when loosening the engine mounts. I would go back and loosen with the engine supported and retorque the mount bolts.
Yes, when doing the mounts i just supported the engine to replace. Just to clarify, I did the mounts 3 years ago due to both pipes sagging. New mounts solved that and improved handling. When I say I raised the engine, it was during the water pump replacement. After water pump replacement is when i noticed the left pipe was lower.
After reading some of the engine mount issue posts about them failing in only a few thousand miles, I'm thinking the second issue
I mention in post #1 could be a failed engine mount.
I'm in the same boat as you with the tail pipe...I just did the water pump and now my left tip is lower. I thought it was the mount but when I pulled it, it looked fine. New mount made no dif.
The engine carrier to block must have a little wiggle (Bolt holes) room and needs to be adjusted. Just my guess.
Good guess. I agree. Going to go back and loosen things up and then re-tighten things as many times til it's right. If I remember correctly, I had to lift the engine up a little to get the bolts to line up with the carrier. I may have kept the engine slightly raised while I tightened everything up. Maybe the engine has to be hanging freely and then things need to be tightened. Or perhaps the left side needs to be raised slightly then tightened since it's the left exhaust that's affected.
If the engine hangs freely it's on the ground. I just did my mounts, and raised the engine until it was as raised it can get, then torqued everything, and when I removed the jacks everything was at the right height.
Not talking about the mounts being loosened, you're not following. Talking about loosening the bolts and things that are required when doing the water pump replacement. Letting the engine "hang freely" means not tightening all those bits fully while the engine is supported by a floor jack. The way I replaced the water pump requires the engine to be lifted slightly, the engine mounts are not involved.
