996 Forum 1999-2005
New AOS Failing?
Old 08-14-2019 | 03:47 PM
DBJoe996's Avatar
DBJoe996
I wouldn't bother. How are you going to get back there and do it? Removing all that stuff including the intake manifold again is just asking for trouble. Once you run a new section of hose from the fitting to the nipple, you could trim the existing hoses running to the AOS back a bit and cap those...effectively capping the AOS coolant ports off.
Old 08-14-2019 | 04:07 PM
808Bill's Avatar
808Bill
I can jack it up and barely get my hand up to it from the bottom if needed. But, I'm all for taking the path of least resistance!
Thank you all for you help.
Old 08-14-2019 | 07:13 PM
Porschetech3's Avatar
Porschetech3
Originally Posted by 808Bill
Should I cap of the coolant ports on the AOS?
Doesn't matter, you can leave the AOS ports open, no harm will come. You must cap the coolant lines, either at the AOS or at the origin, or run a by-pass line.
Old 08-14-2019 | 07:34 PM
808Bill's Avatar
808Bill
I'll just use a barbed fitting and connect the two since I have one lying around somewhere.
Old 08-14-2019 | 10:02 PM
Kris Murphy's Avatar
Kris Murphy
Originally Posted by Mike Murphy
3 times? Wow, what the heck is that all about? Was something causing it to fail? How did it fail the first time?
First time, I swapped out because I was replacing the motor with a used motor, and did not know how old it was. Second time is because the AOS hates the track. Third time was because the AOS hates the track.
The third time, I got the old one out in 52 minutes. Once you know where the intake bolts are, it is actually easy.
Old 08-14-2019 | 11:47 PM
rhkwon's Avatar
rhkwon
No need to cap
Old 08-15-2019 | 02:11 AM
Mike Murphy's Avatar
Mike Murphy
Did you do any of the last 2 with the engine in the car?
Old 08-15-2019 | 05:05 AM
pdxmotorhead's Avatar
pdxmotorhead
If its any consolation, BMW's have and AOS and its a total piece of crap too..
The BMW one freezes up in the winter as well.
Costa a grand on a E46 to change out the whole deal, lines and unit, and OIL DIPSTICK housing cause its part of it..
Old 08-15-2019 | 09:57 AM
Kris Murphy
I did number 2 and 3 with the motor in the car. Totally doable.
Mike Murphy (08-16-2019)
Old 08-15-2019 | 10:55 AM
Quadcammer's Avatar
Quadcammer
you LOVE the AOS. Don't lie. Its your favorite part of the car.
Old 08-15-2019 | 11:52 AM
808Bill's Avatar
808Bill
Not so easy on a .2 though.
Old 08-15-2019 | 11:04 PM
Kris Murphy
So true. I've never actually had one go bad. I just get sad when I don't get to see it at least once a year, so I take it out and put it back in again.
Gingerman (08-16-2019)
Quick Reply: New AOS Failing?
