Shifting problem
Good morning everyone.
Drove my car from the garage to the house to wash it. When I parked it, I could not shift into reverse. Not only that, Reverse, 1st, 3rd and 5th are not accessible. I don't know enough about the shifter/cable/trans mechanism to have a clue.
Anyone help?
Langg
Anyone help?
Langg
Cable probably popped off the shift arm on the transmission. You have to get under the car, remove the rear underbody plastic, pop the cable back on the shift arm and wire or zip-tie it in place.
As I said, I don't understand the shift function. There are 2 cables. As I understand, the left cable is reverse and all six forward speeds are on the right cable. If that is so, how can I have 2, 4 and 6 if the cable end popped off?
Langg
Langg
Thats not how they work. I never realy studied them but i do know your description is wrong. U dont really need to know how they work but when the cable clips fail and they fail often the result is the shifting issue u have.
Cables can pop off at either end, or the cable sheathes can lose their anchor point at either end.
I'm guessing it is the latter - one of your cables is no longer firmly attached where it is supposed to be attached to a bracket at either the shifter console assembly or at the bracket on the transmission. It is probably running into an obstruction allowing the 2,4,6 shift, but moving more freely in the R,1,3,6 direction.
Another culprit I've seen is that the caps on the ends of the sheathing come free allowing the sheathing to move when it should be fixed in place. They are held fast by a tab and slot arrangement that can be broken. For me it resulted in mushy shifts, but it was only partially detached. If it was completely separated, it could have the symptoms you describe.
As someone else said, there are small clips that hold them in (on both ends), which can fail or fall off.
Zip ties or safety wire to the rescue.
Just a quick note about zip ties.
Try to get the ones that are either “UL “ approved or milspec.
They are made of good nylon and have a stainless steel piece for a locking tab.
The “Chinese” ones are only plastic or a low grade of nylon.
I get flack every time I say this, but safety wire works great (I prefer it).
