license plate adapter
#31
This is what I used, but I don't remember the parts being this expensive!
https://www.pelicanparts.com/catalog...pg3.htm#item10
#32
Finally measured things...the plate is 12" wide, and the holes in the front bumper are 10" apart.
So, I should be able to use the Porsche adapter, apparently without any black plastic showing on either side of the plate.
#33
NJ requires front plate. i keep mine on the passenger floor. i've passed numerous NJ police over the past 4 months and +5k miles i've driven and haven't been stopped once. if i do get stopped i plan on showing the plate and saying i just had front bumper touched up and haven't replaced it yet or some such story. if i ever get pulled over for speeding i hope it will give the officer an alternative ticket to write me, failure to display plate vs speeding. Just my thoughts on the matter.
I pretty much do the same thing except I don't even keep the front tag in the car. The first thing I did once I signed the paperwork (and it was technically mine) was walk out and remove the front bracket and filled the holes with BumperPlugs. Have not had a single issue yet and even have both front windows tinted which is a no-no and still haven't had an issue. I see tons of modern Porsche's (Macans, Caynenes, etc) in NJ without front tags.
#37
#39
When I lived in CA, I got popped for lack of a front plate in my 2005 Mustang GT.
I was driving quickly on my way to SFO, and the CHP decided to try and get me for speeding. There was a lot of traffic and I saw him weaving through to catch up to me, so I slowed down to the limit, pretty close to my intended exit for off-site parking anyhow. As he slowly drove near me, and then past me, he looked back, saw my missing plates, and pulled me over.
So NOT having plates, in my opinion, is a good way of allowing them to pull you over when they don't like you for some reason, and just need any reason at all in order to get you with something.
I run front plates here in TX because I can't be bothered with all of the different enforcement policies. Some small towns like to generate revenue. State troopers tend to be 100% about public safety and are quite friendly and not at all "revenue generating" in my experience. My city also has very good police who seem to be "safety first, tickets maybe" while the town next door has motorcycle cops whose primary job is revenue generation.
No disrespect to Law Enforcement. Policies differ from city to city and that's why I run a tow-hook adapter front plate.
#40
Commercial bracket
Mine
#41
Won't matter to me, but if the next owner doesn't want/need a front plate, there may be scratches where the plate once was.
#42
I have them on both of my 996 and they don't mar the paint in normal use. Now if you go drive into something and hit plate first, you may have a different result.
#43
Use Leading Edge Tape on the bumper before install, its like clear bra but comes in a roll, very thick clear plastic,, originally made for protecting the leading edge of helicopter and propeller blades. 20 bucks a roll give or take.. more the wider you buy.
#44
The adapter mounts are designed to be flush on the bumper. I don't know if they would work properly w/ something under them.
