Has anyone done an LS3 swap on here?
Hi I recently purchased a 996 with a blown motor looking to swap it out for a LS3 looking on some advice on mounts what company and other things that might be helpful with this engine swap thx
Kiko Alexandrov (06-28-2019)
ls1tech.com decent group minimal drama, they like the swaps, and there are a few on there,, expect to be up
to15K ish into one unless your a real do it yourself-er to the core.
Renegade Hybrids and Kennedy are purveyors of many of the needed/handy parts.
A Turbo style transmission with cooler highly recommended.
Don't fixate on the LS3, there are several options that are more economical IE a L92 is about 5500
in my area(With < 100K on it) ,, its a Escalade all Aluminum 6.2 and your into the 400 HP zone
STOCK. minor tweaks and 500+ and less of the Corvette Legend tax.
Shamelessly plagiarized from the web:
What is the difference between l92 and ls3?
LS3 Heads and the L92 heads are Identical.... only difference between these 2 engines
was the cam and pistons other than that they use the same heads. LS3 intake valves
have a hollow stem, therefore lighter. LS3 heads are designed with hollow valve stems for higher revving.
Compression Ratio10.5:1
Horsepower Rating403 hp <---- This decides how fast you hit something
Torque Rating417 ft./lbs. <---- This decide how far you go through it
There's a few in the Facebook group.
I have an Ls2 in mine. I would personally stay away form Renegade. If I had to do it again, I would buy everything from Andrew (Stuttgart Muscle). Things like engine mount plate/mounts, gas pedal adapter and harness for the C7 pedal, clutch flywheel and trans adapter (although that I would get from Kennedy Engineering personally). Everything else is off the shelf, wire harness, headers, starter and manifold all fit. Exhaust you're left with a custom fab job no matter what. Hope that helps.
The following 3 users liked this post by kondata17:
I am gathering parts for mine. I picked up a renagade engine mount as a good price and i like the sage 2 spec clutch and adaptor by stuggard muscle. im probably gonna build a 8k rpm destroked ls3. I toyed around with the new supercharged lt4 but i think its too much. I have already got upgraded radiators and will probably do the center rad just in case. All the info for the swap is out there u just need to dig.
Don’t think a GM motor won’t need oil mods if you plan to track it. Otherwise, the LS swap is awesome, albeit not easy or cheap to do.
Had some time today and pulled the engine out
already looks like a great start. They only thing I would ask about the Stuttgart Muscle adapter is if it clears the sway bar, otherwise the KEP adapter is the same price. The Kennedy unit comes with a clutch kit (I'm currently running it now). Handles 500 hp and is very street friendly. I've owned BMW Ls swapped cars, driven swapped Rx-7's and a v8 boxster. The 996 is by far my favorite.
I'd love a "simple" LS1 swap into mine.
Having a '99 makes it considerably easier from what I understand.
Enjoying my 3.4 for the time being. Will look into it down the road for sure.
