996 Forum 1999-2005
Who has done the factory short block swap?
Old 04-19-2020, 03:34 AM
  #31
yelcab
yelcab's Avatar
Almost any standard OBD2 scanners that have live data will show you fuel trims. Expect it to cost at least $200.
Old 04-19-2020, 02:20 PM
  #32
wsrgklt
wsrgklt's Avatar
I ended up with the OBD Fusion scan tool app on my phone, which reads live data and only costs $10. As it turns out, my long term trims are running high. Since it's a bit off topic for this thread, I started a new one to explore correcting the issue https://rennlist.com/forums/996-foru...l#post16560580
Old 04-20-2020, 03:56 AM
  #33
pdxmotorhead
pdxmotorhead's Avatar
FWIW,, my Little Bosche bluetooth running their app on my Iphone unit reads out the fuel trims, got it at O'reillys for working on
a Honda before I got the 996,, its worked on most OBDII rigs I've tried it on. I got it on sale for 60 bucks..
wsrgklt (04-20-2020)
Old 04-20-2020, 02:21 PM
  #34
jjbravo
jjbravo's Avatar
My son and I did the factory short block, and sent the heads to Hoffman. 3,000 miles later, I couldn’t be happier. Only regret? Didn’t pull the outer seal on the case-split style IMS bearing.
Old 04-20-2020, 05:04 PM
  #35
Imo000
Captain Obvious
Super User
Imo000's Avatar
You can't get to the front seal if you pull the flange?
Old 04-20-2020, 05:07 PM
  #36
jjbravo
jjbravo's Avatar
Pull the flange to get to the rear one, but the bearing and other seal are inaccessible unless you split the engine.
I should have pulled the flange.
Oh well. Next RMS or clutch...
Old 04-20-2020, 07:34 PM
  #37
wsrgklt
wsrgklt's Avatar
Impressive! Congrats on doing it yourself, and I'm glad you're running strong 3,000 miles later.
Old 04-21-2020, 10:43 AM
  #38
Imo000
Captain Obvious
Super User
Imo000's Avatar
In that case I wouldn't have split the case for this. It's a real PITA to put it all back together and then there is the risk not properly installing the wrist pin clips. You'll be fine, don't worry about it.
work_truck (01-13-2022)
Old 01-13-2022, 01:15 PM
  #39
Eurocarguy911
Eurocarguy911's Avatar
As this is my decision to address a hole in the coolant sleeve on cylinder #1, a cracked head above cylinder #2, and bore score on cylinders # 4, 5, and 6, I'm interested in finding out how this option went for others. Reviving this thread as to not clutter up the feed.
If you've done this, or have any insights it would be great to hear them here.
Best,
The following 2 users liked this post by Eurocarguy911:
GC996 (01-13-2022), work_truck (01-13-2022)
Quick Reply: Who has done the factory short block swap?
