What kind of jack do you use? Harbor Freight any good?
I’m not talking about the whole car lift. They have some lifts that look like they would meet both jack points and lift half the car.
Otherwise what do you use to lift your car?
Had this one for about 9 years:
https://www.amazon.com/Compact-Aluminum-Racing-Jack-Rapid/dp/B009SX8494/ref=asc_df_B009SX8494/?tag=hyprod-20&linkCode=df0&hvadid=309705947946&hvpos=1o3&hvnetw=g&hvrand=12962651105139961171&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9026941&hvtargid=pla-569972873405&psc=1
Gets the job done.
Also the handle separates in half and makes a great breaker bar.
![https://www.amazon.com/Compact-Aluminum-Racing-Jack-Rapid/dp/B009SX8494/ref=asc_df_B009SX8494/?tag=hyprod-20&linkCode=df0&hvadid=309705947946&hvpos=1o3&hvnetw=g&hvrand=12962651105139961171&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9026941&hvtargid=pla-569972873405&psc=1](https://rennlist.com/forums/images/misc/amazon_icon.gif)
Gets the job done.
I've used a Craftsman aluminum floor jack for about 12 years. Very reliable. I don't think Craftsman actually made it, I think it's a rebrand of some other company. The one time I had to buy a simple part for it (part of the universal joint in the handle/valve assembly cracked), the same part was listed for Omega, Michelin, Pro-Lift, and Blackhawk. I don't know if you can buy this anymore since Craftsman is in a questionable state. Schwaben makes some stuff that looks almost identical.
![](https://rennlist.com/forums/attachments/996-forum/183847d1176160242-hydraulic-floor-jack-craljack04.jpg)
Harbor Freight 3-ton low profile is low enough to slide right under my sump plate and jack the car from the center member. It’s perfect. And cheap.
I currently use an Arcan jack that I bought at Costco in May of 2015.
Previous to that I had a Craftsman jack for about 6 months.
It failed without warning while in use, so I threw it away.(I was angry when the intercooler it was raising, suddenly dropped on me)![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Before that I had a Craftsman jack that I'd owned for 27 years.
I should have kept it, but wanted a larger heavy duty jack.![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
If I were in the market for a jack today, I would buy one of these:
https://www.harborfreight.com/automo...uty-63183.html
I keep thinking about buying one, even though there is nothing wrong with my Arcan.
If I had a little more room, I'd get it just to have a second jack, but then again I also could use a transmission jack...hmm...
I currently use an Arcan jack that I bought at Costco about in May of 2015.
One caveat is the type of suspension on your car. Mine is stock, so the M030 folks might have an issue with either.
Measure twice and cut once!
FYI, I did a bunch of measuring between the regular HF low profile and the Daytona low profile. I found that the HF version had a bit more reach to access the car from the rear. I don’t think the Daytona will clear the sump plate.
I've been thinking about lowering my car just a bit.
I probably need to measure first.
My last car(BMW 135i) was stock height (sport suspension) and I had to drive it up on a board in order to get the Arcan jack underneath to the center jackpoint on the subframe.
