If your ac was off the cooling fans wont operate until those temps. If your ac was on then those temps are not out of line for stop and go hot day traffic. But i would still have a look and make sure things are working like both front fans and whens the last time the bumper was removed for a radiator clean up?
Not sure if they kicked on. I just leave the AC pretty much the entire time. Forget about it as it turns on everytime you go to auto mode.
I've had the car about 9 months and havent done it myself. Maybe I will make that a project this week or next as Inwont be working.
At what point are the fans on? When do they jump to high?
Currently, I am in the middle of cleaning the radiators out. Will post pics in a bit.
The passenger fan comes on instantly with the AC on while the driver side is off. Then when jumping to high, both come on. Is this normal? Or am I looking at a faulty fan or short for the low speed.
Not normal. Both fans should come on high or low.
Electric fans
There are two radiator modules installed in the front of the vehicle (on the jleft- and right-hand side). These radiators are each fitted with an electric fan. They can be operated at two speeds and are activated by the DME control unit whenever the following conditions apply:
Electric fan, speed 1
(Ground to DME control unit, terminal 35)
Coolant temperature higher than 96.75°C or air conditioning switched on.
Electric fan, speed 2
(Ground to DME control unit, terminal 36)
Coolant temperature > 102°C or air-conditioning fluid pressure switch closed (coolant pressure > 16 bar).
Note: The electric fans for the radiators are only triggered when the engine is running!
Engine bay fan:
The engine compartment purge fan rarely comes on.
From the service manual...
"Switch-on conditions for engine compartment fan (this fan pulls air into the engine compartment) The engine compartment fan is switched on when the engine compartment temperature is > 176 degrees F or the coolant temperature is > 216 degrees F.
After-running of engine compartment fan
If the ignition is switched off and the engine compartment temperature is more than 140 degrees F, the DME control module remains in readiness for another 20 minutes. During this time, the engine compartment temperature is retrieved every 10 seconds. If the engine compartment temperature is > 185 degrees F , the engine compartment fan is switched on for 20 seconds. If the engine compartment temperature is still > 185 degrees F after this time, the fan remains on for a further 30 seconds."
Here is the long explanation from the service manual on the flashing coolant light.
2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high -- light is lit; pointer on the right
4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right
Note: The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously."
Engine bay fan:
Terminal 35, I assume would be in tone of the large round connectors?
I am assuming it's more likely for the fan to have a malfunction than the ground going out. I guess I will look into testing the ground tomorrow, assuming i can track it.
I wouldn’t worry about speed being off. Most of these are off by several mph. I would tend to trust GPS the most.
This was more of a curiosity thing. I am used to my motorcycle being about 10% high on the speedometer reading.
Figured the OBD may be known to be most accurate being that its computer driven. Then again, it wouldnt make sense for that to be off from the digital reading on the dash.
