996 Forum 1999-2005
Installed Continental TRD7412
Old Mar 19, 2019 | 01:14 PM
S_Lee's Avatar
S_Lee
Default Installed Continental TRD7412
First, a HUGE thank you to Tore at Bergvill F/X! He held my hand through the entire install and went above and beyond - best customer service I've seen.
I got the TRD7412 since it won't scream "hey I've got a nice stereo, steal me" and it has modern tech.
I wasn't sure which harness I would need, so I sent Tore some pics of the back of the stock radio; he suggested the BOSE harness, which was spot on (even though I have the base sound system).
Turns out, I had a Frankenstein...The stock head unit was the CDR-23, but since I had no amp and only 4 speakers, the MOST connector was just looped back on itself.
When I got it installed, the Conti wouldn't power on/off with ignition, so I sent more pics of the harness to Tore, and he was able identify that I had the 2004 model "Facelift radio + Radio Preparation M441" which does not have the Terminal 86S wire (ignition switch).
He suggested bridging the ISO A pin 4 (the yellow/red wire in his harness) to the ignition switched circuit on the Climate Control Unit harness (connector D, pin 9, black/blue wire).
That worked and the Conti sounds so much better than the stock (garbage) unit and the wife is happy since she doesn't appreciate the Fabspeed "music" as much as I do
Old Mar 19, 2019 | 09:44 PM
Porschetech3's Avatar
Porschetech3
Yes I too like the looks of the Conti head units in a 996..
Old Mar 19, 2019 | 10:28 PM
De Jeeper's Avatar
De Jeeper
Did u get the sticker too? And x2 on bergvill being a good company.
mine
Old Mar 20, 2019 | 12:15 AM
crimony's Avatar
crimony
Can I ask where you decided to mount the microphone, and how it performs?
Cheers.
Old Mar 20, 2019 | 08:26 AM
ToreB's Avatar
ToreB
Thanks for the nice feedback guys, I highly appreciate this!
Cheers,
Tore
Old Mar 20, 2019 | 08:52 AM
De Jeeper's Avatar
De Jeeper
I did not use the mic on my install. I perfer an earbud for phone calls.
Old Mar 20, 2019 | 11:05 AM
wyovino's Avatar
wyovino
Cheers.
I don't have that radio, but I mounted my mic above the driver side sunvisor in the A-pillar. That location works very well, even in my cabriolet.
Old Mar 20, 2019 | 06:53 PM
S_Lee's Avatar
S_Lee
Yep, same spot for me and works well.
Old Mar 21, 2019 | 02:36 PM
Ace Tub's Avatar
Ace Tub
So I had the BOSE MOST and the CDR-23 and I went with the same head unit and LOVE the way it looks and functions. I have been dealing with alternator whine though, I am almost to the point of trying to redo the wiring to see if I can get rid of it.
No weird noises with your setup?
Old Mar 21, 2019 | 03:35 PM
S_Lee's Avatar
S_Lee
I haven't noticed any whining (my exhaust is a little loud though so it might drown it out). Engine noise through the speakers is usually a loose ground wire, from what I remember.
