Gasoline additive?
Received 5,413 Likes
Use the Techron before every oil change.
Why AFTER a fresh oil change?
Add Techron to full tank, drive till very low, refill, then get oil changed. I learned this many years ago from Charles Navarro.
One of many good threads here:
https://rennlist.com/forums/997-foru...how-often.html
If you fill up at Chevron exclusively you don't need to add Techron, it has it already.
lowpue - If you have an older engine that has some blow by, adding the techron will dilute the oil, so best before an oil change.
dak911 - if you have doubts about where the car was fueled before you purchased it, go ahead and put in a bottle of techron regardless of when the oil change is.
I have used Liqui Moly Jectron
https://products.liqui-moly.us/addit...n-cleaner.html
parris:
My simplistic understanding is, as the additive circulates through the system, combustion by-product contaminant levels in the oil spike from detergent effect. The back of the valve is sprayed by the injector. The valve is lubricated. That’s one point of cross-contamination. Another is oil gravity leak down through block to the sump. I believe AOS is another. The Techron bottle concentration is like 10x the normal pump fuel ratio...so quickly makes the oil dirtier.
I have a bottle of the Driven stuff also, haven't tried it out yet though. I'm also very curious how it stacks up against Techron.
Well I bought ten, not sure if that constitutes a case or not. I bought it for its purported fuel stabilization and preservation qualities as much as for any benefit to the injectors. Unfortunately, some cars sit for a lot longer than I like.
parris:
Captain Obvious
Super User
Super User
parris:
Quote:
Originally Posted by hatchetf15
parris:
Imo000: Where did you read this snake oil explanation?
Same place you get your daily positive affirmations.
parris:
