Engine Failure AFTER IMS replacement
Also, I did the clutch and AOS. I didn't realize it, but my clutch had worn down to the rivets. The AOS was still performing okay, but the manometer reading was a little low and so it was replaced to save future labor costs.
My expansion tank now has a crack in it and I blame all the people here at Rennlist, cause I think the problem has become contagious. hahaha This is the year of expansion!
I've seen people burn up new clutches in a matter of minutes. Some people can destroy anything.
The Carrera GT has a special take-off procedure that MUST be followed or the triple disk carbon fiber clutch will be toasted.
Basically, the throttle cannot be depressed while take-off, the computer will sense clutch release and will adjust REV and THROTTLE as nessesary, then after clutch is fully released you can depress throttle. The engine will rev so fast and so high that trying to do it your self will result in a burnt clutch to the tune of 10,000 bucks !! I have seen these clutches burnt out while leaving the dealership, on a slight hill going onto the main road.
Former Vendor
Pre- Qualification procedures were developed, and are a required procedure for all Certified Installers for good reasons.
We are a few days into our November IMS Solution Clinic here at Flat 6. We set aside November and May for these semi- annual installation Clinics and do all the IMS Solution work at these times only.
So far, 6 days in and we've qualified one 996 out of four that have arrived for the service. The other 3 had debris laden oil, high cam deviations, or failing cylinders. Keep in mind that all of these vehicles came from out of state and all of them went through a preliminary check sheet inspection before we accepted the jobs. The local shops that carried these things out simply failed to do their jobs, and we found all of these issues immediately upon arrival here at Flat 6. One of them was diagnosed audibly and we knew it had a failing cylinder right off the truck. We held the truck to confirm this, and we packed it up and sent the car right back home again.
People just don't pay attention. If the car "runs fine" they assume that its all perfect inside. This could not be further from the truth.
On the flip side we are seeing a ton of technicians that are seeing warning signs and not reporting the issues, and just marching forward with the installation of the IMS retrofit kit. Why? Well, because they work on a commission based pay scale and if they do the right thing, they lose money at the end of the week. They are penalized for doing the right thing, so even good ones choose to do the wrong thing.
These are the reasons why choosing an IMS Solution Certified Installer simply makes sense. No one else has anything to lose, and they don't have to answer for their mistakes, or inadequacies. Certified Installers have a lot to lose. They will lose it with one single infraction, and they know it.
Former Vendor
I watched a video that was recently posted to YouTube where a shop was preparing to install an LN IMS retrofit bearing. The video looked to be more promotional in nature, but basically they just checked the oil and moved onto installing the bearing. Skipped over all 10 other steps you have listed in the install manual.
After years of me prodding him, Mr. Raby has finally agreed to start a YouTube channel (Rennvision) and one of these first videos is on the topic of pre- qualification. This video is aimed toward the DIY/ non- professional installer of IMS products and hits all the vital points.
Subscribe to the channel, several videos are being shot each month and will soon be posted on a weekly basis, all technical in nature, and the vast majority focus on the M96/ M97 engine.
Oh, this is great news! I learned a lot from the PCA videos and look forward to seeing more from Jake Raby. I really appreciate his contribution to the DIY Porsche community.
Fantastic video, thank you! What does it mean?
I got a fuel trim 2.39 on bank one, all else at 1.0
MAF is reading 12-15
Could this be why I get a little surge at idle once in a while?
Great videos!
I've watched all of them so far.
Looking forward to seeing more.
