Door Lock Assembly DIY Fix gone wrong. Door won't close
here are some videos from yesterday. The white door panel clips (I think 9 in total) are 0.36 each on Autohausaz I ordered like 20 some break every time.
Mechanical Issue shown 3 minutes
How lock works mechanically 1 minute
Mechanical Issue fixed and lock assembly disassembly tips
7 minutes
7 minutes
2nd UPDATE:
The passenger latch (the one that started the whole mess) continued to fail in a couple of ways after reinstall. The replacement arrived early so I replaced it today. I have gotten the entire process down to about 15 minutes thanks to all this practice. There are plenty of door disassembly tutorials and videos out there... my favorite is https://rennlist.com/forums/996-foru...-detailed.html
I wish I had seen it sooner
White door retaining clips 99950758240
Passenger door lock assembly is 3B1837016P
Thanks for taking the time to document this. I replaced my driver side latch and now I'm sorry that I didn't save the old one,
2nd UPDATE:
thanks for this write up. I repaired the solder joints in my door latch about six months ago and got window working properly but I messed up something on the locking mechanism so now the door does not lock. The latch works fine so I think I must have missaligneed the lock tab when re-assembling. I've been putting it off because I didn't want to have to pull the passenger door mechanism to compare but your videos will help me immensely and save me from having to pull both! Cheers to you sir!
That is an amazing find. I've been seeing them in the $400+ range lately.
