2004 996 C2 Engine quit
So I have a follow up to the rattle sound I was hearing and posted about previously- (described as a clatter or knocking sound when at partial throttle and between about 2500-3500 rpm).
The engine quit running 2 days ago while stopped at a red light. It was at normal operating temperature and I had driven about 50 miles already that day, 10 just prior to the engine dying. It was running normally right up until when it stopped. My girlfriend was driving and I though maybe she just stalled it- but it wouldn't even turn over with the starter. I pushed it clear of the highway (about 100 yards to the next street, thank you to a random stranger who hopped out of his car and helped me push!)
It seemed like the battery was low as the engine wasn't turning at all. I connected a portable jumpstart pack I keep in the car and after 5 minutes tried it again. This time it fired up briefly and ran very rough with an awful mechanical sound- I shut it off immediately. It is now at the independent Porsche mechanic shop in my area. The mechanic has an excellent reputation and I'm sure he will be able to find the cause- I'm just hoping the motor isn't ruined!
My best guess is that the water pump seized and induced enough drag to stall the at idle engine, and then the starter motor didn't have sufficient torque to rotate the engine with a frozen water pump (Though i suspect it would be able to just drag the belt over the pulley if it were frozen stiff). There were no fluid leaks at all and no indications in the coolant tank or on the oil dipstick of intermix, but I did note some small black particulates in the coolant tank. I drained and refilled the coolant and replaced the water pump with a Gates brand aftermarket unit about 1000 miles ago.
Does anyone have a different guess? I'll update this thread with what my mechanic discovers.
Does the Gates brand have metal or plastic impellers? When a water pump goes out of wack, with plastic impellers they just break as to not damage the block. So with one of those, it shouldn't seize the engine. You can start the engine without aux belt for a short period of time though, although mechanical noise doesn't sound good.
Do you have any soundbites of your rattle and/or the mechanical noise?
Yea, there is pretty much no way a water pump impeller is going to stop the engine force. It would only take a few HP to shear it to pieces. I don't think you're going to find anything good in there. Sorry to say that, but hoping for the best.
Thanks for the replies. The impeller blades on the replacement water pump were plastic. Still no word on the outcome. And unfortunately I don't have any recordings of the sound it made.
It's hard to say. I only heard it for about 3 seconds (upon starting the engine after it had just died). It ran with a terrible clatter noise accompanying it, and I shut it right off. I had replaced the IMS bearing and bolt with the Pelican Parts kit just a couple of months ago. It went in easily and I'll really be surprised if it is an IMS bearing failure.
So sorry to hear this.
You should have never restarted your car! That may have caused an additional $$$ in collateral damage...My timing chain broke and PO tried the restart. I'm in the same boat!
Well, as always hindsight is 20/20. As OP said, he thought it simply stalled due to low battery. No way to avoid that.
Similar thing happened in my 1999 C2.
Stopped at a red light & my car died. Restarted it, and it died again almost immediately.
I knew it wasn't good when I saw coolant pouring out the exhaust as the wrecker was loading it up.
Yes, I totally agree. Any other car I would have done the same. I hope it's not to serious and OP will be up and running before me!
