996 Forum 1999-2005
DIY: 996 Door Latch Replacement [Detailed]
Old 12-28-2023, 03:13 PM
  #91
mig.
mig.'s Avatar
Drivers side door latch is 8N1837015A ..
Old 04-04-2024, 09:14 AM
  #92
NewbieFromNY
NewbieFromNY's Avatar
Doing is if the latch microswitch I ordered doesn't work.
Thanks OP for the post. Full of WIN
Old 04-29-2024, 01:36 PM
  #93
QwikKotaTX
QwikKotaTX's Avatar
In an attempt to check functions, my remote is no longer locking the doors on my car.
I was using a screwdriver to close the latch with the door open. The window dropped but does not go back up when I cycle the door handle. With doors open, the dash lights do not come on as they did before. Only the interior lights come on. Is there a way to reset this?
Old 05-04-2024, 09:05 PM
  #94
QwikKotaTX
QwikKotaTX's Avatar
Thank you very much for all who posted in this thread! I was able to fix my window not staying dropped issue with a cheap VW latch. I mated the Porsche electronics housing with the VW mechanicals and soldered the new latch rotary switch to the old red and blue wires. $12 from eBay and the fob and alarm works correctly.
Old 05-30-2024, 06:04 PM
  #95
RL911
RL911's Avatar
Great thread. One thing not mentioned relates to the black plastic piece the door handle threaded screw slides into. My URO mechanism I just got did not have this piece. Is it correct that I should just swap it from the original to the new one I have? Looks like it should just slide out.
thx
Quick Reply: DIY: 996 Door Latch Replacement [Detailed]
